I’m using Telegraf to collect data from a network device using the gnmi input plugin.
I’m receiving data like this:
"fields": {
"lsps/constrained_path/tunnels/tunnel/state/counters/byteRate": 0,
"lsps/constrained_path/tunnels/tunnel/state/counters/bytes": 1234,
"lsps/constrained_path/tunnels/tunnel/state/counters/packetRate": 0,
"lsps/constrained_path/tunnels/tunnel/state/counters/packets": 10
"name": "lsps",
"tags": {
"/mpls/lsps/constrained-path/tunnels/tunnel/state/counters/name": "oc-123456",
"component": "aftd-trio",
"component_id": "1",
"host": "gnmi-deployment-telegraf-agent",
"interface-name": "device1-device2-0-XE",
"path": "/mpls/lsps/constrained-path/tunnels/tunnel/state/counters",
"sub_component_id": "0",
"source": "networkdevice1.mgt.net"
"timestamp": 1707409986
This is my telegraf.conf:
[global_tags]
[agent]
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 500000
flush_interval = "10s"
debug = false
quiet = false
hostname = "telegraf-agent"
omit_hostname = false
[[inputs.gnmi]]
addresses = ["device1.mgt.net"]
username = "$user"
password = "$password"
encoding = "proto"
redial = "10s"
enable_tls = true
tls_ca = "/etc/telegraf/router_ca.pem"
insecure_skip_verify = true
vendor_specific = ["juniper_header"]
[inputs.gnmi.aliases]
optics = "/interfaces"
opticsVendor = "/components"
lsps = "/mpls"
[[inputs.gnmi.subscription]]
name = "lsps"
origin = "openconfig-interfaces"
path = "/junos/services/label-switched-path/usage/"
subscription_mode = "sample"
sample_interval = "60s"
[[processors.rename]]
[[processors.rename.replace]]
tag = "name"
dest = "interface-name"
[[processors.regex]]
namepass = ["lsps"]
[[processors.regex.tag_rename]]
pattern = "source"
replacement = "system-id"
result_key = "keep"
[[outputs.file]]
files = ["stdout"]
I have specified the result_key = "keep", because I want to keep the original tag, however, the original tag source is not coming through. Only the replacement tag system-id is coming through and is assigned the value of source. I’m expecting to see both source and system-id come through as tags with the same value.
I have replicated this on Docker Telegraf Alpine versions 1.28.5 and 1.29.3.
