OS: Ubuntu 14.04 amd64
telegraf --version
Telegraf 1.12.3 (git: HEAD 16784bca)
I am collecting IPMI data using the ipmi_sensor input module. I have a need to replace the value of a certain tag by key name. Some servers report temperature by setting “name” to “ssb_temp” while others use “system_temp” - I am attempting to normalize all input by replacing all instances of “name=ssb_temp” tag with “name=system_temp” tag.
Here are the relevant config blocks:
# PROCESSOR PLUGINS #
[[processors.strings]]
[[processors.strings.replace]]
tag = "name"
old = "ssb_temp"
new = "system_temp"
# INPUT PLUGINS #
[[inputs.ipmi_sensor]]
name_override = "node_sensors"
servers = ["<redacted>:<redacted>@lan(10.0.0.213)", "<redacted>:<redacted>@lan(10.0.0.214)"]
[inputs.ipmi_sensor.tagpass]
name = [ "ps1_status", "ps2_status", "ssb_temp", "system_temp" ]
## Timeout for the ipmitool command to complete
timeout = "10s"
## Schema Version: (Optional, defaults to version 1)
metric_version = 2
Collecting the sensor data works fine. However, no matter what I try (strings.replace or regex.tags), I cannot get “ssb_temp” to convert to “system_temp”. Here is example of output:
/usr/bin/telegraf -config /etc/telegraf/telegraf.conf --input-filter ipmi_sensor --test
2019-10-17T20:50:45Z I! Starting Telegraf 1.12.3
node_sensors,cloud=irvine-ops-01,name=system_temp,server=10.0.0.214,unit=degrees_c status=1i,value=33 1571345446000000000
node_sensors,cloud=irvine-ops-01,name=ps1_status,server=10.0.0.214 status=1i,value=1 1571345446000000000
node_sensors,cloud=irvine-ops-01,name=ssb_temp,server=10.0.0.213,unit=degrees_c status=1i,value=38 1571345447000000000
node_sensors,cloud=irvine-ops-01,name=ps1_status,server=10.0.0.213 status=1i,value=0 1571345447000000000
node_sensors,cloud=irvine-ops-01,name=ps2_status,server=10.0.0.213 status=1i,value=0 1571345447000000000
I feel like I must be misunderstanding how this replace filter is supposed to work. I only have this one processor defined. Setting “order” doesn’t make any difference (as expected as there is only one processor defined).
I don’t see anything useful in “-debug” output. I’m hoping someone can either point me in the right direction, or advise on if there is some sort of verbose mode where I can evaluate each processor execution and the results.
Thanks in advance.
Jeremy
