Hi everyone!
I’m having trouble using the Telegraf regex processor to extract and write a new tag into a test bucket.
Current Situation:
- I successfully use the regex processor to extract a date from a string (
OF) and convert it into a timestamp (timestamp_extracted) for our production bucket. - Now, I need to extract another part of the same string to create a new tag (
Formula) and write it to a test bucket to avoid impacting the production environment.
Problem:
- Despite my configuration, the
Formulatag is not appearing in the test bucket. - I suspect there might be an issue with the processor chain or how I’m testing the new configuration.
##### current timestamp
[[processors.regex]]
# Apply the regex only to the desired metric
namepass = ["Production"]
[[processors.regex.fields]]
# The specific field to process
key = "OF" # Adjust this to the field name in which the value is stored
pattern = "^(\\d{14})-.*" # Regular expression to extract the first 14 digits (timestamp part)
replacement = "${1}" # Extracted timestamp will be placed here
result_key = "timestamp_extracted" # Store the result in a temporary field
[[processors.timestamp]]
# Specify the measurement name
# The field containing the extracted timestamp
field = "timestamp_extracted"
# The format of the source timestamp (yyyyMMddHHmmss)
source_timestamp_format = "20060102150405"
# The target format of the timestamp, convert it to unix time (or adjust as needed)
destination_timestamp_format = "unix"
# Timezone options (optional). Set as needed, or it defaults to UTC
source_timestamp_timezone = "Europe/Madrid"
destination_timestamp_timezone = "UTC"
[[processors.converter]]
[processors.converter.fields]
# Use the converted timestamp as the new metric timestamp
timestamp = ["timestamp_extracted"]
# Specify the format of the timestamp
timestamp_format = "unix" # This should match the format you're converting to (e.g., 'unix', 'unix_ms', etc.)
########### Testing new Tag
[[processors.regex.tags]]
key = "OF"
pattern = "^(?:.{15})(.*)$" # Capture the second part after the 14-digit timestamp
replacement = "${1}" # Place the second part (production identifier) here
result_key = "Formula"
namepass = ["Production2"]
[processors.converter.tags]
# Use the converted Formula as the new metric
string = ["Formula"]
## INPUT PLUGINS ##
############################ Production bucket#########################
# Grupo OF
[[inputs.opcua_listener.group]]
name = "Production"
namespace = "2"
identifier_type = "s"
default_tags = { Planta = "2", BucketDestino = "planta" }
[[inputs.opcua_listener.group.nodes]]
name = "OF"
identifier = "ECMS1.ProductionNumber"
default_tags = { Linea = "1", Maquina = "ECMS1" }
monitoring_params = {sampling_interval="0s", queue_size=10, discard_oldest=true}
name = "OF"
identifier = "ECMS2.ProductionNumber"
default_tags = { Linea = "1", Maquina = "ECMS2" }
name = "OF"
identifier = "ECMS3.ProductionNumber"
default_tags = { Linea = "2", Maquina = "ECMS3" }
name = "OF"
identifier = "ECMS4.ProductionNumber"
default_tags = { Linea = "2", Maquina = "ECMS4" }
######################### Test new tag ###################
# Grupo OF2
name = "Production2"
namespace = "2"
default_tags = { Planta = "2", BucketDestino = "Test" }
name = "OF"
name = "OF"
name = "OF"
name = "OF"
Any help or advice is greatly appreciated!
Best Regards
Alejandro A
