I have the following Influx Telegraf / InfluxDB Cloud 2.0 issue:
I’m sending an event MQTT message like this, containing a new event as well as the list of all currently active issues:
"timestamp": "2025-03-07T14:00:00.000Z",
"event": {
"type": "CONNECTION_QUALITY",
"state": "BAD",
"metadata": {
"failures": 59,
"failureRate": "0.98"
"severity": "CRITICAL"
"active_issues": [
"since": "2025-03-07T14:00:00.000Z",
"last_update": "2025-03-07T14:00:00.000Z",
"state": "BAD",
"severity": "CRITICAL",
"metadata": {
"failures": 59,
"type": "MEMORY_ALMOST_FULL",
"since": "2025-03-07T12:00:00.000Z",
"last_update": "2025-03-07T12:00:00.000Z",
"status": "ACTIVE",
"severity": "WARNING",
"metadata": {
"usedMemory": 123456
My goal would be to declare type a tag and put state, status, severity into separate fields. metadata is something I can’t set for all types now and I don’t want to customize this config every time a new type is added. So, I would like to declare metadata as a plain string because I assume Telegraf / InfluxDB cannot automatically create sub-jsons. The same is true for the array of active_issues.
Now, using that config:
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
hostname = ""
omit_hostname = true
debug = false
quiet = false
[[outputs.file]]
files = ["stdout"]
#tagexclude = ["topic"]
# Bucket 'site'
[[outputs.influxdb_v2]]
urls = ["https://eu-central-1-1.aws.cloud2.influxdata.com"]
token = "$INFLUX_TOKEN"
organization = "MyOrg"
bucket = "site"
user_agent = "telegraf_bucket_site"
namepass = [""events"]
# site / events
# Read system and component status events from MQTT
[[inputs.mqtt_consumer]]
servers = ["ssl://123456789012-ats.iot.eu-west-1.amazonaws.com:8883"]
tls_ca = "/tmp/telegraf/AmazonRootCA1.pem"
tls_cert = "/tmp/telegraf/telegraf-certificate.pem"
tls_key = "/tmp/telegraf/telegraf-key.pem"
client_id = "telegraf_status"
persistent_session = true
qos = 1
topics = ["controller/+/events"]
name_override = "events"
data_format = "json_v2"
precision = "1s"
# Extract the 'controller_id' from the topic:
topic = "controller/+/events"
tags = "_/controller_id/_"
timestamp_path = "timestamp"
timestamp_format = "2006-01-02T15:04:05Z07:00"
# Turn event.code into a Telegraf "tag"
[[inputs.mqtt_consumer.json_v2.tag]]
path = "event.type"
rename = "event_type"
# Turn event.status into a string field
path = "event.status"
type = "string"
rename = "status"
optional = true
# Turn event.state into a string field
path = "event.state"
type = "string"
rename = "state"
optional = true
# Turn event.severity into a string field
path = "event.severity"
type = "string"
rename = "severity"
# Store the entire event.metadata object as one JSON string
path = "event.metadata"
rename = "metadata"
type = "string" # <- THIS IS IGNORED
optional = true
# Store the entire active_issues array (with all nested data) as one JSON string
path = "active_issues"
rename = "active_issues"
type = "string" # <- THIS IS IGNORED AS WELL
optional = true
… I end up having this in the database:
#group,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false,false
#datatype,string,string,string,string,string,string,string,string,string,string,string,string,string,string,string,string,dateTime:RFC3339
#default,,,,,,,,,,,,,,,,,
,active_issues_code,active_issues_last_update,active_issues_metadata_failureRate,active_issues_metadata_failures,active_issues_metadata_meta1,active_issues_metadata_meta2,active_issues_metadata_usedMemory,active_issues_severity,active_issues_since,active_issues_state,active_issues_status,active_issues_type,controller_id,event_type,severity,state,time
,,2025-03-07T12:00:00.000Z,0.98,59,,,123456,WARNING,2025-03-07T12:45:00.000Z,BAD,ACTIVE,MEMORY_ALMOST_FULL,Controller_123456,CONNECTION_QUALITY,CRITICAL,BAD,2025-03-07T14:46:00Z
So, I try to tell Telegraf to handle metadata and active_issues like plain strings but it’s ignoring that part of the configuration.
Instead of having plain strings like {"failures": 59, "failureRate": "0.98"} it’s flattening the JSON inside metadata into 'active_issues_metadata_failures and active_issues_metadata_failureRate.
The same is happening with the JSON inside active_issues.
I couldn’t find a way to stop Telegraf to flatten my JSON. How can I do this, how can I declare a json to be treated like a string?
