I have an mqtt input consumer that parses almost perfectly but a bit of data is missing. I am having issues getting one field from an array into influx.
By default almost everything makes it into influxdb but the string inside of gtw_id field is excluded. I have no way of changing the data format; it’s out of my control. I was able to achieve partially desired results with the following config
data_format = "json"
json_query = "metadata.gateways"
json_string_fields = ["gtw_id"]
This give me the gtw_id field but the only problem with this config is that it excludes almost all of the other keys and fields. What can I do to get all of the json parsed an into influx?
Here is my json:
"app_id": "app0",
"dev_id": "dev0",
"hardware_serial": "AAAAAAAA",
"port": 99,
"counter": 685,
"payload_raw": "AHMnlQFnARsCaHcDAGQEAQA=",
"payload_fields": {
"barometric_pressure_0": 1013.3,
"digital_in_3": 100,
"digital_out_4": 0,
"relative_humidity_2": 59.5,
"temperature_1": 28.3
"metadata": {
"time": "2019-03-26T21:55:45.207597292Z",
"frequency": 903.9,
"modulation": "LORA",
"data_rate": "SF7BW125",
"airtime": 71936000,
"coding_rate": "4/5",
"gateways": [
"gtw_id": "gateway0",
"gtw_trusted": true,
"timestamp": 3231141555,
"time": "2019-03-26T21:55:45.163165111Z",
"channel": 0,
"rssi": -38,
"snr": 9.5,
"rf_chain": 0,
"latitude": 00.399174,
"longitude": 00.25094
"longitude": -00.25094,
"location_source": "registry"
Thanks!
