Help request: Json parsing
Dear community,
I am a bit desperated trying to parse a json payload comming in a MQTT message to be stored in influxdb. The payload is following OPC UA PubSub Part14 specification so I think will be helpful for a lot of people. An example of the payload is the following:
{"MessageId":"936107","MessageType":"ua-data","PublisherId":"ua-test-fronius","Messages":[{"DataSetWriterId":28715,"Timestamp":"2023-11-29T22:22:13.323661Z","Payload":{"ConnectedToBroker":{"Value":true}}},{"DataSetWriterId":7076,"Timestamp":"2023-11-29T22:22:13.3237068Z","Payload":{"ConnectedToCloudStorage":{"Value":false}}},{"DataSetWriterId":36507,"Timestamp":"2023-11-29T22:22:13.3237082Z","Payload":{"NumOpcSessions":{"Value":0}}},{"DataSetWriterId":62162,"Timestamp":"2023-11-29T22:22:13.3237088Z","Payload":{"NumOpcSubscriptions":{"Value":1}}},{"DataSetWriterId":60075,"Timestamp":"2023-11-29T22:22:13.3237094Z","Payload":{"NumOpcMonitoredItems":{"Value":74}}},{"DataSetWriterId":58227,"Timestamp":"2023-11-29T22:22:13.3237099Z","Payload":{"QueueCapacity":{"Value":1000}}},{"DataSetWriterId":20362,"Timestamp":"2023-11-29T22:22:13.3237105Z","Payload":{"QueueCount":{"Value":"6"}}},{"DataSetWriterId":11913,"Timestamp":"2023-11-29T22:22:13.3237112Z","Payload":{"EnqueueFailures":{"Value":"0"}}},{"DataSetWriterId":37064,"Timestamp":"2023-11-29T22:22:13.3237932Z","Payload":{"SentMessages":{"Value":"935317"}}},{"DataSetWriterId":45217,"Timestamp":"2023-11-29T22:22:13.3237938Z","Payload":{"BrokerMessageSize":{"Value":"455"}}},{"DataSetWriterId":58512,"Timestamp":"2023-11-29T22:22:13.3237944Z","Payload":{"BrokerMessageLatency":{"Value":"0"}}},{"DataSetWriterId":20143,"Timestamp":"2023-11-29T22:22:13.3237953Z","Payload":{"BrokerMessagesSecond":{"Value":0}}},{"DataSetWriterId":62951,"Timestamp":"2023-11-29T22:22:13.3237958Z","Payload":{"NumOpcMonitoredItemsSecond":{"Value":0}}},{"DataSetWriterId":10713,"Timestamp":"2023-11-29T22:22:13.3237963Z","Payload":{"BrokerMessageSendFailures":{"Value":"0"}}},{"DataSetWriterId":41506,"Timestamp":"2023-11-29T22:22:13.3244247Z","Payload":{"CurrentWorkingSetMBs":{"Value":"260"}}}]}
An the expected output, for example for the last line would be:
CurrentWorkingSetMBs,DataSetWriterId=41506,PublisherId="ua-test-fronius",MessageType="ua-data" Value=260 (converted timestamp "2023-11-29T22:22:13.3244247Z").
Could someone help me with the json or json_v2 parsing? I read all the examples but none of them reflects a similar structure.
Thank you very much in advance,
Please, could someone help me to parse the payload? I tried several methods but I am not able to find a solution when there is no key pair inside the Payload…
THANKS in advance
Hi , to increase the odds of someone helping you, you could “pretty print” the json to eliminate the left-right scrolling which is really really hard for humans to process.
You can do this with python out of the box
python -mjson.tool < yourjsonfile.txt
Edit your original post or reply with the formatted version in a </> pre-formatted text block
You are fully right:
  "MessageId": "936107",
  "MessageType": "ua-data",
  "PublisherId": "ua-test-fronius",
  "Messages": [
      "DataSetWriterId": 28715,
      "Timestamp": "2023-11-29T22:22:13.323661Z",
      "Payload": {
        "ConnectedToBroker": {
          "Value": true
      "DataSetWriterId": 7076,
      "Timestamp": "2023-11-29T22:22:13.3237068Z",
      "Payload": {
        "ConnectedToCloudStorage": {
          "Value": false
      "DataSetWriterId": 36507,
      "Timestamp": "2023-11-29T22:22:13.3237082Z",
      "Payload": {
        "NumOpcSessions": {
          "Value": 0
      "DataSetWriterId": 62162,
      "Timestamp": "2023-11-29T22:22:13.3237088Z",
      "Payload": {
        "NumOpcSubscriptions": {
          "Value": 1
      "DataSetWriterId": 60075,
      "Timestamp": "2023-11-29T22:22:13.3237094Z",
      "Payload": {
        "NumOpcMonitoredItems": {
          "Value": 74
      "DataSetWriterId": 58227,
      "Timestamp": "2023-11-29T22:22:13.3237099Z",
      "Payload": {
        "QueueCapacity": {
          "Value": 1000
      "DataSetWriterId": 20362,
      "Timestamp": "2023-11-29T22:22:13.3237105Z",
      "Payload": {
        "QueueCount": {
          "Value": "6"
      "DataSetWriterId": 11913,
      "Timestamp": "2023-11-29T22:22:13.3237112Z",
      "Payload": {
        "EnqueueFailures": {
          "Value": "0"
      "DataSetWriterId": 37064,
      "Timestamp": "2023-11-29T22:22:13.3237932Z",
      "Payload": {
        "SentMessages": {
          "Value": "935317"
      "DataSetWriterId": 45217,
      "Timestamp": "2023-11-29T22:22:13.3237938Z",
      "Payload": {
        "BrokerMessageSize": {
          "Value": "455"
      "DataSetWriterId": 58512,
      "Timestamp": "2023-11-29T22:22:13.3237944Z",
      "Payload": {
        "BrokerMessageLatency": {
          "Value": "0"
      "DataSetWriterId": 20143,
      "Timestamp": "2023-11-29T22:22:13.3237953Z",
      "Payload": {
        "BrokerMessagesSecond": {
          "Value": 0
      "DataSetWriterId": 62951,
      "Timestamp": "2023-11-29T22:22:13.3237958Z",
      "Payload": {
        "NumOpcMonitoredItemsSecond": {
          "Value": 0
      "DataSetWriterId": 10713,
      "Timestamp": "2023-11-29T22:22:13.3237963Z",
      "Payload": {
        "BrokerMessageSendFailures": {
          "Value": "0"
      "DataSetWriterId": 41506,
      "Timestamp": "2023-11-29T22:22:13.3244247Z",
      "Payload": {
        "CurrentWorkingSetMBs": {
          "Value": "260"
Better to read.
Thanks for the advice.
In addition to what FixTestRepeat mentioned, showing your work would help. This is not the first time you have asked the community to figure out the parsing for you. In fact, I took the Xpath config you were given last time and applied it to the new data:
[[inputs.file]]
  files = ["metrics.json"]
  data_format = "xpath_json"
  xpath_allow_empty_selection = true
  xpath_native_types = true
  [[inputs.file.xpath]]
    metric_name = "'CurrentWorkingSetMBs'"
    metric_selection = "//Messages/*"
    timestamp = "Timestamp"
    timestamp_format = "2006-01-02T15:04:05.9999999Z"
    field_selection = "/Payload/*/Value"
    [inputs.file.xpath.tags]
      MessageType   = "/MessageType"
      PublisherId = "/PublisherId"
      DataSetWriterId = "DataSetWriterId"
CurrentWorkingSetMBs,DataSetWriterId=28715,MessageType=ua-data,PublisherId=ua-test-fronius Value=true 1701296533323661000
CurrentWorkingSetMBs,DataSetWriterId=7076,MessageType=ua-data,PublisherId=ua-test-fronius Value=false 1701296533323706800
CurrentWorkingSetMBs,DataSetWriterId=36507,MessageType=ua-data,PublisherId=ua-test-fronius Value=0 1701296533323708200
CurrentWorkingSetMBs,DataSetWriterId=62162,MessageType=ua-data,PublisherId=ua-test-fronius Value=1 1701296533323708800
CurrentWorkingSetMBs,DataSetWriterId=60075,MessageType=ua-data,PublisherId=ua-test-fronius Value=74 1701296533323709400
CurrentWorkingSetMBs,DataSetWriterId=58227,MessageType=ua-data,PublisherId=ua-test-fronius Value=1000 1701296533323709900
CurrentWorkingSetMBs,DataSetWriterId=20362,MessageType=ua-data,PublisherId=ua-test-fronius Value="6" 1701296533323710500
CurrentWorkingSetMBs,DataSetWriterId=11913,MessageType=ua-data,PublisherId=ua-test-fronius Value="0" 1701296533323711200
CurrentWorkingSetMBs,DataSetWriterId=37064,MessageType=ua-data,PublisherId=ua-test-fronius Value="935317" 1701296533323793200
CurrentWorkingSetMBs,DataSetWriterId=45217,MessageType=ua-data,PublisherId=ua-test-fronius Value="455" 1701296533323793800
CurrentWorkingSetMBs,DataSetWriterId=58512,MessageType=ua-data,PublisherId=ua-test-fronius Value="0" 1701296533323794400
CurrentWorkingSetMBs,DataSetWriterId=20143,MessageType=ua-data,PublisherId=ua-test-fronius Value=0 1701296533323795300
CurrentWorkingSetMBs,DataSetWriterId=62951,MessageType=ua-data,PublisherId=ua-test-fronius Value=0 1701296533323795800
CurrentWorkingSetMBs,DataSetWriterId=10713,MessageType=ua-data,PublisherId=ua-test-fronius Value="0" 1701296533323796300
CurrentWorkingSetMBs,DataSetWriterId=41506,MessageType=ua-data,PublisherId=ua-test-fronius Value="260" 1701296533324424700
Thank you very much…sorry for bother you but json_xpath is not well documented at all. In your example you have hardcoded the name of the metric, nevertheless, as you see in my example, the name is changing…how could I retrieve this name when it is not a objetc in the json?
Thanks in advance
This is when you take a step back and look at the config that was provided to you. How are the other fields dynamically set? Can you apply the same thing to the metric_name field?
In short you need to provide the path to the value you want (e.g. /Payload/*), but you want the value itself, and wrap it e.g. name(/Payload/*)`. Both of these are laid out in the xpath docs.
In the future, please provide what you actually tried when asking for assistance.
Thanks. Now I better understand xpath and I see the power of the parser…Thanks @jpowers
