Hi, I am new to Influx and Telegraf. I am trying to setup Telegraf to parse JSON payload from an MQTT input. The problem is my payload (not under my control) is having dynamic field values. It is a flat structure something like this below.
'timestamp': '2024-03-19 13:09:00',
'SN': 'AMG2100-DEMO-001',
'Dynamic_Field_1': 1,
'Dynamic_Field_2': 'OU',
'Dynamic_Field_3': 'NONE',
'Dynamic_Field_4': 101.1,
'Dynamic_Field_5': 'PPB',
The names of the fields denoted by dynamic above change from product to product although the data type remains same.
I tried the json_v2 parser as a first attempt but I think it does not support dynamic keys. Then I am trying the *XPath parser plugin with the following configuration (Also tried some variations of it). But I am getting errors such as plugin inputs.file: line 169: configuration specified the fields ["xpath"], but they were not used. This is either a typo or this config option does not exist in this version.
My telegraf config looks like this:
[[inputs.mqtt_consumer]]
servers = ["tcp://MY-MQTT-BROKER:1883"]
## Topics that will be subscribed to.
topics = [
"MY-TOPIC/SUB-TOPIC/#",
username = "USERNAME"
password = "PASSWORD"
data_format = "xpath_json"
[[inputs.mqtt_consumer.xpath]]
# metric_selection = "/"
timestamp = "time"
timestamp_format = "2006-01-02 15:04:05Z"
field_selection = "*"
[inputs.file.xpath.tags]
name = "string('Sensor Product)"
# device = "string('Sensor data')"
Am I expecting correct that the xpath json parser is the right plugin for my use case? If yes, then where am I going wrong? If no, is there any other alternative plugin?
Thank you very much,
Gopal
