Consider the following json (from an MQTT message):
"device_id": "sp-e4a465",
"mac": "AA:BB:CC:11:22:33",
"timestamp": 1736666999,
"metrics": [
{"name": "co2", "value": 450},
{"name": "temperature", "value": 22.5}
I’d like to store it like this in InfluxDB:
| time | device_id (tag) | co2 (field) | temperature (field) |
| 1736666999 | sp-e4a465 | 450 | 22.5 |
Because I think it’s the most logical way to store this data. Each message can have an a arbitrary number of metrics in the array, with arbitrary metric names, so everything must be dynamic.
This question here json - Telegraf json_string_fields for string arrays - Stack Overflow is similar, but in addition, I also need to name the fields themselves according to the “name” value in the json.
I’m sure it’s possible using json_v2 or xpath but I’m new to Telegraf and can’t figure it out. Thank you for your help.
