I’ve run into a challenging data parsing problem, and would appreciate any help from more expert users here. How can I use telegraf to parse the only string value of a JSON payload, and split it into two float data points?
Background
To monitor the status of a vehicle I keep across the country for family adventures to the National Parks, I’m using a Teltonika FMM00A OBD-GPS device. It measures time and location from GPS, reads statistics from the car’s OBD port, and transmits to a user specified MQTT server.
I’m attempting to use telegraf to pull this data from the MQTT server, and store it in a an influxdb2 server I run, allowing it to be visualized in grafana. I’m currently running telegraf instances for other data that’s stored and visualized. The format of these OBD sensors is causing me an issue I’ve been unable to resolve.
Details
The data from the OBD sensor looks like (carriage returns added for readability):
MQTT Topic: device_imei / data
{"state":{"reported":{"ts":1720354973000,
"pr":0,"latlng":"XX.905603,-YY.399940",
"alt":132,"ang":189,"sat":7,"sp":0,"evt":240,
"239":0,"240":0,"21":5,"200":0,"69":1,"181":17,
"182":14,"66":13434,"67":4047,"68":0,"241":310260,
"16":408}}}
(XX and YY are used to obscure actual device location.)
Telegraf Config
My telegraf config reads all but one of these values appropriately, and of course it’s the one I’m most interested in: latlng. There’s no configuration option on the device to change the format of this JSON payload, nor to have it transmit latlng as separate floats rather than a single string.
# Consume messages from Teltonika GPS OBD via MQTT
# Global tags can be specified here in key="value" format.
[global_tags]
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
# debug = false
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = true
[[outputs.influxdb_v2]]
urls = ["https://influx_server"]
token = "token_here"
organization = "org"
bucket = "teltonika_gps_mqtt"
# Read metrics from MQTT topic(s)
[[inputs.mqtt_consumer]]
servers = ["ssl://mqtt_server:8883"]
topics = [
"device_imei/#",
client_id = "telegraf_teltonika"
username = "user_name"
password = "password"
data_format = "json"
For reasons I don’t understand, I can only use data_format = "json". When I attempt to use json_v2, telegraf never posts the data to the influxdb2 bucket.
Problem
I think the solution is to parse the string into two different floats (for lat and lng), but I’m stuck at how to do that. This post on splitting mqtt json seems to depend on using the json_v2 data format, as does this guide on payload parsing.
Any suggestions or advice? Thank you in advance.
