I just tried to set up a couple of VMs in Azure’s East US 2 region, and attempting to install telegraf failed with an HTTP 404. The version being installed by apt-get is 1.5.0-1, while the currently available packages on the Debian (wheezy/stable) repo are 1.5.1-1.
After a bit of troubleshooting, I came to the conclusion that the content being served by CloudFront from the cache seems to be stale in some parts (or, the changes have not yet propagated). When I attempt to fetch the Packages.gz file used by the aptitude system/programs, the headers show different values for Last-Modified (8 Jan v/s 11 Jan). Sample output is available at this gist.
I confirmed that this is not a transient issue, by trying apt-get commands from my provisioning tool, from the CLI, as well as manually fetching the Packages.gz (as seen in the Github Gist above). I can also reproduce this on multiple VMs in the same region/DC, but this issue does not reproduce on other Azure regions.
Is this the right place to post an issue like this? If not, kindly redirect me to the appropriate location/forum. If you need additional information on this, please do let me know. I’ll try my best to fetch more debug logs.
