So using the new InfluxDB stack (2.0), and with the limited documentation the only place to ask some questions is here. By the way, awesome platform!
I currently have influxdb 2.0 and telegraf running both as docker containers. I also configured telegraf to receive metrics from my VM.
Now I want to go one step further and configure my Azure IoT hub/TTN/Function Apps or AWS equivalent to InfluxDB. If I understand the stack correctly, Telegraf is used to receive metrics from Xsource and Kapacitor is used as a streaming service to enrich the data pulled in by Telegraf.
When configuring a Scraper I do not have many options. Is there still something like “/write” to POST my data to? And does that have to be in prometheus/line protocol format?
Thanks for the awesome work guys!
