It seems the GPG key at https://repos.influxdata.com/influxdb.key was updated on Jan 26th. Since then I have been unable to install telegraf. I have tried removing the public key and letting it redownload, and I’ve tried installing different versions of the package. Is this something you’re working on?
-Jason
Downloading packages:
warning: /var/cache/yum/x86_64/7/influxdb/packages/telegraf-1.9.1-1.x86_64.rpm: Header V4 RSA/SHA512 Signature, key ID 7df8b07e: NOKEY
Retrieving key from xx(can only have 2 links in my post)
The GPG keys listed for the “InfluxDB Repository - RHEL 7” repository are already installed but they are not correct for this package.
Check that the correct key URLs are configured for this repository.
Failing package is: telegraf-1.9.1-1.x86_64
GPG Keys are configured as: https://repos.influxdata.com/influxdb.key
