Hi, I am trying to run a file plugin to load a csv file and it is getting loaded with success but what i am seeing it is loading a extra tag filed called Host. Why it is loading any idea?
The telegraf agent inserts the hostname of the system running the plugin. You can change this in the telegraf configuration file.
There is a setting omit_hostname = false
Change that to omit_hostname = true
Restart the agent after changing that and it should stop inserting the host value. The value will still appear in your old data but not in the new data.
Also, just to make it a bit easier. When you connect to the influx CLI if you pass the following argument
Hi Philb, thanks for reply.
I have changed in the configuration file and set the value to true but again it is ingesting the Host column. i have restarted the telegraf.
