I want to read data from file using Telegraf.
That files are in line protocol:
meas,host=host1 Value=10 1632725859000000000
Telegraf writes data to Influx database.
When I’m logged in a influxdb web interface, I can see _measurement. When i click I can see in second tab _field, but when I click ‘Value’ in field I cannot see any hosts.
Similar situation is when I change ‘_field’ to host by drop-down list. In _measurement I can see host, but this host cannot see _fields.
It looks a little bit like _measurement has access to _field and host and ‘host’ has no access to _field and vice versa.
Hello @Patryk,
Yes InfluxDB structures the output of data written to InfluxDB a differently than relational DBs. That line would produce the following table:
host is a tag in your line protocol and value is a field. Fields keys and field values are split into two columns. Tag keys are given their own column and tag values are contained in the tag key column.
You don’t have access to other values across fields or tags because they’re different data elements.
I’m new influxdb user and if I understood your answer correct, I would need to have more details in that line protocol, but I don’t understand why in almost the same situation It works properly.
Hello @Patryk,
The line protocol you shared: exec,host=example1 Result_0=10, Result_1=10 1632899183000000000
would produce a write errror: Failed to write data invalid write protocol submitted
Because there is space in between your field values. This is correct: exec,host=example1 Result_0=10,Result_1=10 1632899183000000000
I don’t know if that’s a cause for any of your problems.
What do you mean by almost the same situation it works properly? What do you mean with the host it looks the same?
Tag keys might not be populating because you might not have written a tag (tags are optional).
Can you switch to the Script Builder and try:
from(bucket: "<mybucket>")
|> range(start: 0)
This will allow you to query for all of your data.
I"m sorry. In this example I made a mistake. This line protocol which I shared has no space between field. I meant, the situation is the same, because In this exampe:
I read this ine protocol from Rest API which is JSON file. It looks almost the same like this:
Only difference is that this second line protocol is read from the file.
And as I said, when I run “telegraf test” and “telegraf debug” I see no errors.
But when I try to get datas in influxdb, I see no data.
I do not understand why It did not work, because the line protocol “created” from API and read from file are almost the same.
