I have files which I need to parse once in 1h, file contains around 9k lines separated with comma
Telegrad config
[[inputs.file]]
files = [“/tmp/*.log”]
name_override = “test”
data_format = “csv”
csv_header_row_count = 0
csv_column_names = [“time”,“hostname”,“host”,“field1”,“field2”,“field3”,“value”]
csv_delimiter = “,”
Sample data
2024-03-03 13:00:00,hostname,MANAGER,Total_Disk_Usage_of_/opt/log/var,8
2024-03-03 13:00:00,hostname,SERVER@test-033-occ1,1_19089 CXC_1730371_01,DDS_CPU_Usage_of_OCC_Node,0
For some reason, when I write to influx, I got only one line in influx
If I do outputs.file I got all measurements in file
[[outputs.file]]
files = [“stdout”, “/tmp/metrics.out”]
data_format = “influx”
What could be the issue when writing into influxdb?
