I am trying to load the data into influxdb from txt file using. I am following the instructions from Getting Started: Writing Data to InfluxDB | InfluxData
2. Importing directly into InfluxDB
But its failing. Am I doing anything wrong ?
Hello @aditya,
I just noticed that I forgot to make changes to that repo. Thanks for the reminder! The timestamps have an extra 0. I have fixed import.txt. Here is the link to the corrected txt file. I couldn’t upload the entire txt file here so here is a smaller portion in case you want to try it quickly sample_import.txt (1.7 KB)
