I’m new to InfluxDB and I’m trying to import data from the .txt file to my database . I copied the data from the sample data provided by the official page. I changed the name of database in the .txt file to make it match mydb. When I use the similar command it didn’t work:
Thank you. I think it worked. But another problem came out.
It showed that “error”:"unable to parse ‘h2o_feet,location=coyote_creek water_level=8.120,level\\ description=“between 6 and 9 feet” 1566000000\’: invalid field format.
But I did NOT change anything in the data. Is there anything wrong?
