I have data in a text file as below…
DML
CONTEXT-DATABASE: import
CONTEXT-RETENTION-POLICY: oneyear
FO,type=FreshOrders avg_FreshOrders=1479.0840707964599,p95_FreshOrders=2589,FreshOrders=226 1593648000000
FO,type=FreshOrders avg_FreshOrders=2242.86170212766,p95_FreshOrders=5622,FreshOrders=188 1593475200000
FO,type=FreshOrders avg_FreshOrders=1682.3375,p95_FreshOrders=2738,FreshOrders=160 1593734400000
I placed this text file in a folder called data inside influxDB. My requirement is to import last 3 lines of data into influx DB. I am navigating into influxDB folder C:\Users\Administrator\Downloads\influxdb-1.8.0_windows_amd64\influxdb-1.8.0-1 and running the below command in command prompt to import it
influx -import -path=C:\Users\Administrator\Downloads\influxdb-1.8.0_windows_amd64\influxdb-1.8.0-1\data\import.txt -precision=ns
But data is not getting imported and getting below error. Can someone please help me in resolving this issue?
C:\Users\Administrator\Downloads\influxdb-1.8.0_windows_amd64\influxdb-1.8.0-1>influx -import -path=C:\Users\Administrator\Downloads\influxdb-1.8.0_windows_amd64\influxdb-1.8.0-1\data\import.txt -precision=s
2020/07/13 16:34:25 error: error parsing query: found DML, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
2020/07/13 16:34:25 error: error parsing query: found CONTEXT, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
2020/07/13 16:34:25 error: error parsing query: found FO, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
