CLI -Import command does not seem to be working in 1.7.4
I’m running Influx 1.7.4 on a Windows OS and can’t get the “influx -Import” command to work. I even tried this example shown below in the Influx Docs and many other variations with no luck.
Is anyone else having this issue? I can figure out what I’m missing or if there’s a bug. Here’s the error…
C:...\Influx\influxdb-1.7.4-1>influx -import -path=datarrr.txt -precision=s
2019/02/22 15:47:53 error writing batch: {“error”:"unable to parse ‘treasures,captain_id=dread_pira
te_roberts value=801 1550865814\r’: bad timestamp\nunable to parse ‘treasures,captain_id=flint value
=29 1550865814\r’: bad timestamp\nunable to parse ‘treasures,captain_id=sparrow value=38 1550865814
r’: bad timestamp\nunable to parse ‘treasures,captain_id=tetra value=47 1550865814\r’: bad timestamp
2019/02/22 15:47:53 treasures,captain_id=dread_pirate_roberts value=801 1550865814
treasures,captain_id=flint value=29 1550865814
ERROR: 4 points were not inserted
I’m also getting this error…
C:...\Influx\influxdb-1.7.4-1>influx -import -path=LPData00001.txt
2019/02/22 15:51:37 error: error parsing query: found ?, expected SELECT, DELETE, SHOW, CREATE, DROP
, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
2019/02/22 15:51:37 error: error parsing query: found JimsMeasurement01649, expected SELECT, DELETE,
SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
Where LPData00001.txt = …
DML
CONTEXT-DATABASE: JimsDB2
JimsMeasurement01649,EngUnit=PPM Status=“Good”,Value=52.1166419620319 1420088400000000000
JimsMeasurement01649,EngUnit=PPM Status=“Good”,Value=94.9015425680828 1420088410000000000
Hi Jim ,
the first problem looks like some special characters in your file
around the timestamp ?
the second problem probably too because I assume you have # in your file
like this ( without the single quotes to make the # visible in this post ) ?
'# DML
'# CONTEXT-DATABASE: JimsDB2
have a nice weekend ,
Marc
Hi Marc,
Thanks for the reply. I’m still stuck on this issue which seems like a very basic task. I’m uploading a data file and BAT file for your review. Let me know if you see anything wrong.
Edit.BAT.txt (45 Bytes)
datarrr.txt (261 Bytes)
Here’s the error…
C:…\Influx\influxdb-1.7.4-1>influx -import -path=datarrr.
2019/02/25 15:53:09 error writing batch: {“error”:“unable to parse ‘Measurement
88400\r’: bad timestamp\nunable to parse ‘Measurement01649 Value=94 1420088410\r
able to parse ‘Measurement01649 Value=8 1420088420\r’: bad timestamp\nunable to
649 Value=50 1420088430\r’: bad timestamp\nunable to parse 'Measurement01649 Val
bad timestamp”}
2019/02/25 15:53:09 Measurement01649 Value=52 1420088400
Measurement01649 Value=50 1420088430
Measurement01649 Value=94 1420088440
ERROR: 5 points were not inserted
Hi ,
with your uploaded files it works in Linux without any problem,
I tried it on windows , and even if I insert the data manually ,
export it in windows , the exported file cannot be imported it gives the same error.
I have read that “Windows support is considered “experimental” for all components except Telegraf,”
here …
https://www.influxdata.com/blog/running-the-tick-stack-on-windows/
Marc:
Thanks a lot for testing this. I did a bit more research and found this…
I converted the file to Unix style line endings and it now works fine on the Windows instance.
