I’m trying to send alerts to Alerta but I’m getting an error that ‘resource’ and ‘event’ are required fields. I’m using YAMLs for my event handler and task templates.
**My alerta handler:**
topic: main
kind: alerta
options:
token: 'F_pTpZc0zhMz4C46fmpdv2sRPKQGUBHGXXXXXXXX'
token-prefix: 'Key'
resource: '{{ .Name }}'
event: '{{ .ID }}'
group: '{{ .Group }}'
origin: 'kapacitor'
**My task template:**
template-id: main-mean
vars:
measurement:
type: string
value: cpu
where_filter:
type: lambda
value: "\"cpu\" == 'cpu-total'"
groups:
type: list
value:
- type: string
value: "host"
field :
type: string
value: usage_idle
warn :
type: lambda
value: "\"mean\" < 30.0"
crit :
type: lambda
value: "\"mean\" < 10.0"
window :
type: duration
value: 1m
**My tick script:**
dbrp "telegraf"."autogen"
var measurement string
var where_filter = lambda: TRUE
var groups = [*]
var field string
var warn lambda
var crit lambda
var window = 10s
stream
|from()
.measurement(measurement)
.where(where_filter)
.groupBy(groups)
|window()
.period(window)
.every(window)
|mean(field)
|alert()
.id('kapacitor/{{ .Name }}/{{ .Group }}')
.warn(warn)
.crit(crit)
.topic('main')
When the alert is triggered, I see in the logs that Alert id is “kapacitor//” so it seems that I couldn’t get the .Name and the .Group substitution.
Please advise.
