In Kapacitor we have the message property method that, according to the documentation uses a “template” to construct a meaningful message.
From the documentation example, we have:
stream…
.groupBy(‘service’, ‘host’)
.alert()
.id(‘{{ index .Tags “service” }}/{{ index .Tags “host” }}’)
.message(‘{{ .ID }} is {{ .Level}} value: {{ index .Fields “value” }}’)
If the “service” tag contains: ‘authentication’, the “host” tag contains: server123.domain.com, the Level is set to Critical and the “value” field contains 53, then the message is built as:
‘authentication/server123.domain.com is CRITICAL value:53’
Is it possible to use the Lambda functions to build any of the nodes?
Say I need to replace server123.domain.com with device123.domain.com, then by using :
RegexReplace(/server([0-9]+).domain.com/, “host”, ‘device$1.domain.com’). This returns the desired:
device123.domain.com content.
Then the idea is to have the message to contain:
‘authentication/device123.domain.com is CRITICAL value:53’
Thus, .Id must be something like:
.id(‘{{ index .Tags “service” }}/ RegexReplace(/server([0-9]+).domain.com/, “host”, ‘device$1.domain.com’)’) or similar.
Another example:
Say we need .message to contain the upper case version of a field, then something like:
.message(strToUpper(“field_with_lowercase_text”))
