I’m trying to create a template which will serve as my “base” for other alerts:
// the database
var outputDB = 'telegraf'
// the retention policy
var outputRP = 'autogen'
// output measurement
var outputMeasurement = 'alerts'
var triggerType = 'threshold'
// The name of the alert
var name = 'Alert'
// Which measurement to consume
var measurement string
// Optional where filter
var where_filter = lambda: TRUE
// Optional list of group by dimensions
var groups = [*]
// Which field to process
var field string
// Information criteria, has access to 'mean' field
var info lambda
// Warning criteria, has access to 'mean' field
var warn lambda
// Critical criteria, has access to 'mean' field
var crit lambda
// How much data to window
var window = 5m
// The slack channel for alerts
var message = 'This is an alert.'
// Sigma
var infoSig = 2.5
var warnSig = 3
var critSig = 3.5
var data = stream
|from()
.measurement(measurement)
.where(where_filter)
.groupBy(groups)
|window()
.period(window)
.every(window)
|mean(field)
|eval(lambda: sigma("mean"))
.as('sigma')
.keep()
|alert()
.info(info)
.warn(warn)
.crit(crit)
.opsGenie2()
.teams()
.recipients()
var trigger = data
|eval(lambda: float("value"))
.as('value')
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag('alertName', name)
And here’s the generic alert (YAML format):
template-id: generic_alert
dbrps:
- db: telegraf
rp: autogen
vars:
name:
type: string
value: CPU Alert
measurement:
type: string
value: cpu
groups:
type: list
value:
- type: string
value: "host"
field:
type: string
value: cpu-total
message:
type: string
value: "This is test alert."
info:
type: lambda
value: '"mean" > 50.0 OR "sigma" > infoSig'
warn:
type: lambda
value: '"mean" > 80.0 OR "sigma" > warnSig'
crit:
type: lambda
value: '"mean" > 90.0 OR "sigma" > critSig'
window:
type: duration
value: 10m
I am able to “define” this in kapacitor but I’m getting this error when I try to enable it:
Error: Failed to compile stateful expression for info: Failed to handle right node: Failed to handle right node: Given node type is not valid evaluation node: *ast.IdentifierNod
