Hi, @Jay_Clifford
I tried to monitor mqtt multiple topics with telegraf.d (Each profile listens to one mqtt topic & Each topic enters its own unique influxdb data bucket), But I just push messages to a topic, but all data buckets receive and store data
################# telegraf.conf ###################
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "20s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Log at debug level.
debug = true
## Log only error level messages.
# quiet = false
## Log target controls the destination for logs and can be one of "file",
## "stderr" or, on Windows, "eventlog". When set to "file", the output file
## is determined by the "logfile" setting.
# logtarget = "file"
## Name of the file to be logged to when using the "file" logtarget. If set to
## the empty string then logs are written to stderr.
# logfile = ""
## The logfile will be rotated after the time interval specified. When set
## to 0 no time based rotation is performed. Logs are rotated only when
## written to, if there is no log activity rotation may be delayed.
# logfile_rotation_interval = "0d"
## The logfile will be rotated when it becomes larger than the specified
## size. When set to 0 no size based rotation is performed.
# logfile_rotation_max_size = "0MB"
## Maximum number of rotated archives to keep, any older logs are deleted.
## If set to -1, no archives are removed.
# logfile_rotation_max_archives = 5
## Pick a timezone to use when logging or type 'local' for local time.
## Example: America/Chicago
# log_with_timezone = ""
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
######################### telegraf.d health_info.conf ##############################
[[outputs.influxdb_v2]]
## ex: urls = ["https://us-west-2-1.aws.cloud2.influxdata.com"]
urls = ["http://192.168.11.248:8086"]
## Token for authentication.
token = "token"
organization = "org"
bucket = "health_info"
## The value of this tag will be used to determine the bucket. If this
## tag is not set the 'bucket' option is used as the default.
# bucket_tag = ""
## If true, the bucket tag will not be added to the metric.
# exclude_bucket_tag = false
## Timeout for HTTP messages.
# timeout = "5s"
## Additional HTTP headers
# http_headers = {"X-Special-Header" = "Special-Value"}
## HTTP Proxy override, if unset values the standard proxy environment
## variables are consulted to determine which proxy, if any, should be used.
# http_proxy = "http://corporate.proxy:3128"
## HTTP User-Agent
# user_agent = "telegraf"
## Content-Encoding for write request body, can be set to "gzip" to
## compress body or "identity" to apply no encoding.
# content_encoding = "gzip"
## Enable or disable uint support for writing uints influxdb 2.0.
# influx_uint_support = false
## Optional TLS Config for use on HTTP connections.
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
[[inputs.mqtt_consumer]]
## Broker URLs for the MQTT server or cluster. To connect to multiple
## clusters or standalone servers, use a seperate plugin instance.
## example: servers = ["tcp://localhost:1883"]
## servers = ["ssl://localhost:1883"]
## servers = ["ws://localhost:1883"]
## servers = ["tcp://172.29.60.10:1883"]
servers = ["tcp://192.168.11.248:1883"]
## Topics that will be subscribed to.
topics = [
"/realtime-monitor/health-info/+"
## The message topic will be stored in a tag specified by this value. If set
## to the empty string no topic tag will be created.
# topic_tag = "topic"
## QoS policy for messages
## 0 = at most once
## 1 = at least once
## 2 = exactly once
## When using a QoS of 1 or 2, you should enable persistent_session to allow
## resuming unacknowledged messages.
# qos = 0
## Connection timeout for initial connection in seconds
# connection_timeout = "30s"
## Maximum messages to read from the broker that have not been written by an
## output. For best throughput set based on the number of metrics within
## each message and the size of the output's metric_batch_size.inputs.
## For example, if each message from the queue contains 10 metrics and the
## output metric_batch_size is 1000, setting this to 100 will ensure that a
## full batch is collected and the write is triggered immediately without
## waiting until the next flush_interval.
# max_undelivered_messages = 1000
## Persistent session disables clearing of the client session on connection.
## In order for this option to work you must also set client_id to identify
## the client. To receive messages that arrived while the client is offline,
## also set the qos option to 1 or 2 and don't forget to also set the QoS when
## publishing.
# persistent_session = false
## If unset, a random client ID will be generated.
# client_id = ""
## Username and password to connect MQTT server.
# username = "telegraf"
# password = "metricsmetricsmetricsmetrics"
## Data format to consume.
## more about them here:
data_format = "json"
[[processors.starlark]]
source = '''
def apply(metric):
fields = ["wheel_odometer", "ogm_points"]
for f in fields:
key_prefix = f+"_"
key_len = len(key_prefix)
keys = [x for x in metric.fields.keys() if x.startswith(key_prefix)]
keys = sorted(keys, key=lambda x: int(x[key_len:]))
values = [str(metric.fields.pop(k)) for k in keys]
new_value = "["+', '.join(values)+"]"
metric.fields[f] = new_value
return metric
[[processors.printer]]
############### telegraf.d info.conf #########################
[agent]
interval = "10s"
flush_jitter = "10s"
precision = ""
debug = true
# quiet = false
# logfile = ""
hostname = ""
token = "token"
bucket = "info"
# bucket_tag = ""
# timeout = "5s"
## HTTP User-Agent
topics = [
"/realtime-monitor/vehicle-info/+"
## 0 = at most once
## 2 = exactly once
# qos = 0
## publishing.
# client_id = ""
## Tag keys is an array of keys that should be added as tags. Matching keys
## are no longer saved as fields. Supports wildcard glob matching.
tag_keys = ["name"]
[[inputs.exec]]
## Commands array
commands = []
## measurement name suffix (for separating different commands)
name_suffix = "json"
## When strict is true and a JSON array is being parsed, all objects within the array must be valid
json_strict = false
## Array of glob pattern strings or booleans keys that should be added as string fields.
json_string_fields = ["name"]
This is the configuration file, :pray:
