Hi,@Franky1 Ask a question
The telegraf will be disconnected and reconnected in a few seconds
####################### telegraf ###########################
Configuration for telegraf agent
[agent]
## interval = "2s"
## Rounds collection interval to 'interval'
round_interval = false
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 3000
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
metric_buffer_limit = 30000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "30s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Log at debug level.
debug = true
## Log only error level messages.
## quiet = true
################ input/ output ################
[[outputs.influxdb_v2]]
namepass = ["system_resource_art"]
urls = ["http://172.29.60.9:8086"]
## Token for authentication.
token = "ASzi0c38b0_3H-mwsO8tlE_Wwovtlxu1Mvw39tyjKKj2zvsR611VolXfsxfoc4FzCKu-55cSSJ2G75w4ltLyKA=="
organization = "trunkport"
bucket = "system_resource_art"
# INPUT PLUGINS #
[[inputs.mqtt_consumer]]
## Broker URLs for the MQTT server or cluster. To connect to multiple
## clusters or standalone servers, use a seperate plugin instance.
## example: servers = ["tcp://localhost:1883"]
## servers = ["ssl://localhost:1883"]
## servers = ["ws://localhost:1883"]
## servers = ["tcp://172.29.60.10:1883"]
## Topics that will be subscribed to.
topics = [
"vdcs/system/+"
## If unset, a random client ID will be generated.
client_id = "telegraf_system_resource_art"
## Data format to consume.
## more about them here:
data_format = "json"
tag_keys = ["name"]
name_override = "system_resource_art"
