I want to copy the data from one database to another. That should actually be easy with “select into”. However, the new database has a different structure. This means that the data should be assigned to other tasks and fields. How can I best do this? I would be grateful for every tip.
The source data looks like this:
SELECT mean("value") AS "mean_value" FROM "homeassistant"."autogen"."kWh" WHERE time > :dashboardTime: AND time < :upperDashboardTime: AND "entity_id"='netzeinspeisung_energie_ksem' GROUP BY time(:interval:) FILL(null)
And this is what the target data looks like:
SELECT mean("Netzeinspeisung Energie") AS "mean_Netzeinspeisung Energie" FROM "telegraf"."modbus"."modbus" WHERE time > :dashboardTime: AND time < :upperDashboardTime: AND "name"='KSEM' AND "host"='telegraf' AND "slave_id"='1' AND "type"='holding_register' GROUP BY time(:interval:) FILL(null)
If I can’t get any further with the “select into” command, should it possibly work with a Python script and influxdb-client?
