I need to transfer some data from one database (named “hosting” in my POC) to a new one (named “transfert” in my POC) on the same server.
Then I ran this command : SELECT * INTO transfert..cpu FROM hosting..cpu.
After that I requested for data with my hostname for key “host” and I had a response for each database (all is right) : select * from cpu where host = 'poc-ubu-2203' LIMIT 1.
But when I request a SHOW TAG VALUES FROM "cpu" WITH key = "host" I only have the tags on the source database (hosting).
It is like the tags were not replicated, even if we can filter with WHERE statement on tags in a SELECT command.
I faced this issue on InfluxDB version 1.8.1 and 1.8.10.
My dashboards on Grafana cannot work if I don’t have these tags.
Can someone help me to understaind what happens and how to solve it ?
Here you can find the full test output :
InfluxDB shell version: 1.8.10
time written
0 30942
> use hosting
Using database hosting
> select * from cpu where host = 'poc-ubu-2204' LIMIT 1
time cpu host usage_guest usage_guest_nice usage_idle usage_iowait usage_irq usage_nice usage_softirq usage_steal usage_system usage_user
1701101010000000000 cpu-total poc-ubu-2204 0 0 99.29328621908412 0 0 0 0.050479555779914 0 0.4543160020193963 0.20191822311976357
key value
host poc-ubu-2204
> use transfert
Using database transfert
1701101010000000000 cpu1 poc-ubu-2204 0 0 99.69696969698144 0 0 0 0 0 0.2020202020200257 0.1010101010101564
FYI. Last line requested on hosting and transfert databases is not the same because hosting database continues to recieve data from Telegaf.
Thank you for your help, best regards.
