Migration from influx 1.7.4 to 3.0 - UTF-8 Errors of .lp backup file
I am attempting to migrate and ingest a large, compressed Line Protocol file (mydata.lp.gz) into an InfluxDB 3.0 Core instance. This file is a backup originally pulled from an InfluxDB server hosted 1.7.4 database. During this process, I have encountered persistent issues related to UTF-8 validation errors while using the influxdb3 write CLI command. These issues have prevented successful data ingestion into the new InfluxDB 3.0 environment, which is a self-hosted Core instance running on an Linux VM
A strict character validation error occurred, indicating invalid encoding within the file. The CLI returned the following message:
Error: Write command failed: error reading file: stream did not contain valid UTF-8
This indicates that the original backup data from InfluxDB 1.7.4 may not have been strictly UTF-8 encoded.
Action 1: I attempted to explicitly fix the encoding using iconv with the ignore flag (iconv -f utf-8 -t utf-8 -c mydata_clean.lp > mydata_final.lp). Unfortunately, the UTF-8 validation error persisted even after this step.
Action 2 (Current State): As a final attempt to resolve both memory and encoding, I developed a robust, streaming Python script to read the file line-by-line, ignore non-UTF-8 characters, and write a new, clean file. Despite this, ingestion still fails at the same UTF-8 validation step.
I need help in copying the backup as i am unsure if the mistake is done while copying the backup or is it someting I would face while having a migration from 1.7.4 to 3.0.
Any Leads or feedback on this would be much appreciated.
The problem is with the original data encoding, not so much the migration or copying process. As you have relized, you must ensure your line protocol file is fully UTF-8 compliant before ingestion as strict validation check of UTF 8 went into effect in version 1.7.8 onwards.
Hi Suyash,
Thanks for the Reply. Can you give any solutions of how to resolve this? So I have to do something specific when I am doing the backup from 1.7.4 because I have tried few things with the .lp extension file but without success.
