I have an InfluxDB OSS instance in the a cloud VM. I was able to use the UI to create organizations, buckets, tokens, etc.
However, creating and managing user seems extremely inefficient or even unfeasible (unless I am missing something).
- To create a user, I need to use CLI instead of UI. Seems UI should be the default way.
- The only way for the user to change the password also through CLI? So now I need to provide each new user with a token, and user needs to install influx CLI, configure it to the VM instance, then use CLI to change password? This seems very roundabout and inconvenient for the users
- There’s also no way to assign roles to users besides Member or Admin
Am i missing something obvious or is the outline above the expected sequence?
