I was wondering if someone know if there is a way to use the InfluxDB v2 cli to create a user, assign to a organization and assign the role owner or change the role of a user later.
It seems that there is an API option but not at the CLI.
Also in the UI there seems to be no way to change the role of a user.
Sooooo YES you’re entirely right. This is not a good UX. I’m working on hunting down some issues related to your question but I also encourage you to comment on this
Please see:
I created this issue in case you want to add a comment.
Thank you!
Hi and thanks a lot for the explanations. How would I than update an user? Do I need to delete and recreate the user? Or how to deal with different users and a user should have normal access to Org A and all access to Org B?
