Hello
i installed my influxdb2 following the documentation instructions, the DB is up, the gui is working and data are sent to the influxdb2 through telegraf.
i’m now wanting to create users, for this i downloaded the latest CLI, i created a config using the API token generated (and even the API of the first admin account)
in the console, i have empty result or when i try to create user it say there is no organisation (i checked twice no typo on the name of the organisation
D:\temp\influxdb2-client-2.20>influx user list
ID Name
D:\temp\influxdb2-client-2.20>influx user create --name userlambda --password <password>
Error: no organization with name "lololo"
influx ping say ok
i set influxdb in debug mode to get some infos from influxdb
ts=2021-12-30T10:43:50.627272Z lvl=debug msg=Request log_id=0YjjoJyW000 service=http method=GET host=localhost:8086 path=/api/v2/orgs query="org=lololo" proto=HTTP/1.1 status_code=200 response_size=56 content_length=0 referrer= remote=127.0.0.1:50131 user_agent=influx took=0.525ms body=
ts=2021-12-30T10:43:51.622372Z lvl=debug msg=Request log_id=0YjjoJyW000 service=http method=GET host=localhost:8086 path=/metrics query= proto=HTTP/1.1 status_code=200 response_size=2687 content_length=0 referrer= remote=127.0.0.1:50112 user_agent=Go-http-client took=1.086ms body=
ts=2021-12-30T10:43:52.122471Z lvl=debug msg="user find by ID" log_id=0YjjoJyW000 store=new took=0.000ms
ts=2021-12-30T10:43:52.122471Z lvl=debug msg="orgs find" log_id=0YjjoJyW000 store=new took=0.000ms
ts=2021-12-30T10:43:52.122471Z lvl=debug msg="Orgs retrieved" log_id=0YjjoJyW000 handler=org org=[]
ts=2021-12-30T10:43:52.123011Z lvl=debug msg=Request log_id=0YjjoJyW000 service=http method=GET host=localhost:8086 path=/api/v2/orgs query="org=lololo" proto=HTTP/1.1 status_code=200 response_size=56 content_length=0 referrer= remote=127.0.0.1:50134 user_agent=influx took=0.540ms body=
ts=2021-12-30T10:43:53.190902Z lvl=debug msg="user find by ID" log_id=0YjjoJyW000 store=new took=0.000ms
ts=2021-12-30T10:43:53.190902Z lvl=debug msg="orgs find" log_id=0YjjoJyW000 store=new took=0.000ms
ts=2021-12-30T10:43:53.190902Z lvl=debug msg="Orgs retrieved" log_id=0YjjoJyW000 handler=org org=[]
seems all ok for influxdb
any suggestions?
is there a way to set a debug mode for the CLI?
is there a way the influx.exe ping be more verbose?
regards
Tonic
