I have a new install of influxdb 2 on a raspberry pi 5 using PiBuilder and IOTstack. Docker is up and running as is Portainer-CE and Node-Red. Other yet to access are Mosquitto and Grafana.
It’s been a long install, surprisingly with no errors reported.
I’m trying to access each of the installed applications in turn. docker ps -a shows all containers up and running.
The problem is with the influxdb login. I’m accessing each application by hostname so for influxdb this is raspberrypi.local:8087
There’s no cert for influxdb so it’s just plain http:// etc
The first thing presented is a login screen. I expected to be invited to add a user, but no.
At the login there’s no user/password that gets me in. I’ve tried Administrator/Administrator1, admin/admin, admin/password, root/root and so on…
I’d be grateful if someone can help me over this unexpected obstacle.
Thanks in advance,
Ric
Hi again,
Rooting around the install files I found this:
/home/<~~~~~>IOTstack/.templates/influxdb2/service.yml
… in there we have:
influxdb2:
container_name: influxdb2
image: “influxdb:latest”
restart: unless-stopped
environment:
- TZ=Etc/UTC
- DOCKER_INFLUXDB_INIT_USERNAME=me
- DOCKER_INFLUXDB_INIT_PASSWORD=mypassword
- DOCKER_INFLUXDB_INIT_ORG=myorg
- DOCKER_INFLUXDB_INIT_BUCKET=mybucket
- DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=my-super-secret-auth-token
- DOCKER_INFLUXDB_INIT_MODE=setup
“me”/“mypassword” gets me into both Influxdb and Influxdb2 installed via IOTstack
I’m no longer using IOTstack to install Influx. Besides, the anticipated arrival of Influxdb 3 (or is that Influxdb Edge?) and the reversion to InfluxQL means I won’t need to learn Flux. It’s fresh install time.
Regards,
Ric
