Grafana Datasource: Inxluxdb v2 always Error 401
Hi all,
this is my system:
Raspberry Pi3 (latest OS)
$ cat /etc/*release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
VERSION="11 (bullseye)"
Grafana
$ grafana-server -v
Version 9.1.1 (commit: 9e60a1bff1, branch: HEAD)
InfluxDB v2
$ influx version
Influx CLI 2.4.0 (git: 5c7c34f) build_date: 2022-08-18T19:26:48Z
$ telegraf --version
Telegraf 1.23.4 (git: HEAD 5b48f5da)
Everything installed fine and running as a service.
Problem:
I can not log in to my Influx DB v2 web interface.
  • I open http://192.168.0.211:8086/
  • InfluxDB login screen appears.
  • I log in with admin and my password (only alphanumeric)
  • A red message appears on the right top corner “Could not sign in”
Question:
So how can I reset the admin pasword?
I searched with google to reset password, but the result only supply command which do not work or where I get a “401” Error, like:
influxd upgrade --username='admin' --password='admin' --org='MyOrg' --bucket='MyBucket' --force
also tried with token, same errors … all gave ERR: 401
Could anyone be so kind and help?
If you need further information about the system please feel free to ask.
I am really frustrated, because it seems, that all the google results are for influx v1 :frowning:
Cheers,
Miky
Hi @Miky,
You should be able to look at your original username and password if you inspect the bolt file of InfluxDB. This forum should help you out:
Hi @Jay_Clifford ,
thanks for your advice.
I tried the parts from the mentioned thread:
(1)
$   sudo  influxd inspect
See 'influxd inspect -h' for help
For me its not clear here, what to inspect, that would help me, when I try “-h
(2)
sudo vim /var/lib/influxdb/influxd.bolt
In this file I only see ^@^@^@^@^@^@^@^@^D stuff
but also the admin with the token.
But to log in on the InfluxDB login page I deed a passwort to log in and not a token.
I can extract:
  • userID
  • orgID
  • token
But I cant imagine how that can help me to login with username and password.
SOLUTION
Surprisingly, I could change the admin apssword with the following command:
influx user password -n admin -t MyToken
That solved my problem - I can log in now!
Thanks a lot for pointing me in the right direction :smiley: :+1:
