I’m facing an issue. I’ve created a token for an user inside the admin org. The token have r/w access on a single bucket.
I’ve correctly set up the token by using this command :
influx auth create --read-bucket id_bucket --write-bucket id_bucket -u username --host https://my_host:8086 -o primary_org
With the token generated I can r/w data with influx cli, I can also read data from grafana with the influxdb datasource.
My problem is that I have a 401 Unauthorized access when telegraf write in the bucket influx only with generated tokens. It works well with admin token.
Can someone solve this ?
