Hi - I am using docker-compose to connect my Python application’s container to an InfluxDB container and am experiencing authorization errors (the response is {"code":"unauthorized","message":"unauthorized access"} and I also see "authorization not found" in the InfluxDB container logs.
Initially, my app container is able to connect to the InfluxDB container via http://influxdb:8086 using the credentials supplied as environment variables in the compose YAML (this actually worked all day today, but then suddenly stopped working), but at some seemingly arbitrary point I eventually start to encounter the auth errors. When I try to login via the UI at localhost:8086 I see a "Could not sign in" alert.
I can use those same credentials to run an InfluxDB container alone:
docker run -p 8086:8086 -e DOCKER_INFLUXDB_INIT_MODE=setup \
-e DOCKER_INFLUXDB_INIT_USERNAME=someuser \
... influxdb:2.0.7
and successfully connect/authenticate (both from my app and via the UI). It seems like the authorization only fails when using docker-compose.
Here is the InfluxDB service in my compose YAML:
influxdb:
image: influxdb:2.0.7
secrets:
- influx_user
- influx_password
- influx_token
- influx_org
- influx_bucket
environment:
- DOCKER_INFLUXDB_INIT_MODE=setup
- DOCKER_INFLUXDB_INIT_RETENTION=1w
- DOCKER_INFLUXDB_INIT_USERNAME=/run/secrets/influx_user
- DOCKER_INFLUXDB_INIT_PASSWORD=/run/secrets/influx_password
- DOCKER_INFLUXDB_INIT_ORG=/run/secrets/influx_org
- DOCKER_INFLUXDB_INIT_BUCKET=/run/secrets/influx_bucket
- DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=/run/secrets/influx_token
ports:
- 8086:8086
volumes:
# - influxdb_data:/var/lib/influxdb
- influxdb_data:/root/.influxdbv2
healthcheck:
test: "exit 0"
networks:
- net
I am using docker volumes to persist data and was experimenting with changing the volume mount location, which is why there is a line commented out under the volumes param. I do not understand why this is happening and would appreciate any suggestions. Thank you for your time and consideration.
