Kapacitor's Alert Issue
dbrp “ABC”.“autogen”
var data = stream
|from()
.database(“ABC”)
.retentionPolicy(“autogen”)
.measurement(memoryUtil)
.groupBy(host)
|window()
.period(1m)
.every(1m)
.align()
|median(‘available_percent’)
.as(‘value’)
data
|alert()
.warn(lambda: “value” < warn)
.crit(lambda: “value” < crit)
.stateChangesOnly()
.message(message)
.topic(topic)
Let assume at a particular time My data is:
tags: host=ip-111-111-17-208
time median
1528787490000000000 34.31948838933012
tags: host=ip-111-111-53-24
time median
1528787510000000000 19.15578168915138
tags: host=ip-111-111-84-49
time median
1528787530000000000 14.391669240940798
Question: When I set my critical to less that 30%, I am getting only one alert instead of two. How to get alerts for both the hosts.
e.g. .crit(lambda: “value” < 30)
Because one of them is 34%, which is greater than 30%. If the samples you provided are real
time median
time median
So only one will alert. What was the threshold before?
@philb
I set my critical alert to less that 30 e.g. crit(lambda: “value” < 30). So two machines ip-111-111-53-24 and ip-111-111-84-49 should be generating critical alerts but I get only one.
Sorry i misread your first post.
Have the machines gone into the OK state since generating the first alert? You could try removing the stateChangesOnly and increasing the threshold so they recover - then change the thresholds back.
