Kafka notification endpoint in InfluxDB 2.0
HI everyone,
First of all, I’m new here. I’m curious to know if it possible to migrate my alarms from Kapacitor in influxDB 1.8 that writes the alarms in event Handler Kafka to Influx 2.0
I don’t see the possibility to do this in InfluxDB 2
Could someone help me.
Thanks in advance for your help
Cheers,
Emanuel
Hello @edias88,
Welcome! Are your Kapacitor tasks batch or stream?
Hi Anais,
Thank you for your reply.
I’m using streaming Kapacitor scripts.
Cheers,
Emanuel
Hello @edias88,
Stream tasks are not supported with the backward compatibility as of yet. Please look at:
Thank you.
Hello Anais,
Thanks for getting back to me.
This solution should work for me.
Cheers,
Emanuel
@edias88,
No worries! Thank you :slight_smile:
