We’re exploring the option of using influxDB is the underlying technology suite for a new product.
I have already accomplished:
install influxdb2
connect through external API (Java client)
push data from our system to a bucket.
What I need to do now:
create a stream event which will run on each update to the bucket.
(Nothing fancy for now, just some comparisons on fields and measurements in the bucket)
perform an action in case some conditions in the task code are met.
I have tried saving a data-explorer->query as a task, but that requires a period.
I have tried through the tasks menu -> create a new task, with the same issue.
Could someone please send me in the right direction?
@rawkode May I ask what is the current state of streaming support in InfluxDB 2.0?
I have added a feature request to Grafana to support streaming in InfluxDB data source (as in here) but there does not seem to be any documentation nor any other information about the subject yet besides this thread.
With 2.0 RC ss there already something that could be used to stream data points as they are received by the DB?
@rawkode Is this feature still on your 2021 roadmap? I just would like to have more visibility to make the right choices for my upcoming project.
For the context, I have the same constraints as the OP. Having a 1-minute interval would be too much of a delay. My understanding is that I can use Kapacitor for streaming. But it would add more complexity to the setup and it’s a different DSL to deal with. So I would rather have everything in InfluxDB and use the Flux language.
