Streaming data from one InfluxDB to another with Kapacitor
I have the following use case: I’m gathering data from a sensor which is being saved in a InfluxDB (InfluxDB1 on PC1 running Windows 10). I need to stream this data to a second PC (InfluxDB2 on PC2 with Windows10).
Taking inspiration from here (Continous Query Influxdb without aggregate functions possible? - #4 by noahcrowley) I’ve been able to do so without any problem.
My issue is: if the connection between PC1 and PC2 is interrupted, how can I make sure, that data which has been saved on PC1 during the connection failure, will be updated on PC2 once the connection is established?
I certainly have some ideas how to implement something like this in Python but the question is, if there is something more comfortable to implement.
Hello @golanudelamare,
Great question. I don’t know, give me some time to share your question. Thank you.
Hi @Anaisdg. Thanks for reaching out once again. In the meantime I’ve implemented a solution developed in Python. Nevertheless, it would be interesting to find out, if there is something from the TICK stack that can be used with shorter development time.
Hello @Anaisdg. Any response or ideea? Thanks. Stay safe!
That’s awesome! are you able to share your Python solution? I’ve added this question to an issue with other community questions. I’ll check int.
