I have some weather data coming into InfluxDB from two different sources and am successfully visualising them in Grafana. What I now want to do is mathematically combine two of the values, one from each source, in this equation for wind chill Tch.
Tch = 13.12 + 0.6215Ta - 11.37v^0.16 + 0.3965Ta v^0.16
Ta is a temperature and v is a speed.
I really don’t where to start, is there a way of doing exponents?
Can someone please point me in the right direction.
Try the POW() function:
Antony.
Thanks Antony, a useful link.
I can see how POW() does the exponents but how do I build up the equation above?
I would expect something like:
select (13.12+0.6215Ta-11.37POW(v,0.16)+0.3965TaPOW(v,0.16)) as Tch
…assuming I read your original equation correctly
Antony.
Thanks again, I will experiment!
Not getting much success, everything I have tried gives no result !
These are two working sql statements for the variables I want to combine in my equation. They work fine for graphing individually. avSpeed is v and Outside Temp degC is Ta.
SELECT last("avSpeed") FROM "anenom" WHERE $timeFilter GROUP BY time($__interval) fill(null)
and
SELECT last("Outside Temp degC") FROM "Temperature" WHERE ("location" = 'Home') AND $timeFilter GROUP BY time($__interval) fill(null)
For example:
SELECT POW("avSpeed",0.16) FROM "anenom" WHERE $timeFilter GROUP BY time($__interval) fill(null)
Gives no output at all.
@peterb If using Flux, this kind of operation is definitely possible.
from(bucket: "db/rp")
|> range(start: v.timeRangeStart)
|> filter(fn: (r) => r._measurement == "anenom" or r._measurement == "Temperature")
|> filter(fn: (r) => r._field == "avSpeed" or r._field == "Outside Temp degC")
|> aggregateWindow(every: v.windowPeriod, fn: last)
|> map(fn: (r) => ({ r with Tch: 13.12 + (0.6215 * r.Temperature) - 11.37 * r.anenom^0.16 + 0.3965 * r.Temperature * r.anenom^0.16}))
Thanks Scott. I am a novice to all this so even the relationship of Flux to InfluxDB and Grafana, my visualising tool, is something I have to understand.
Presumably the code above can be entered at the command line but will it:
- Continue to run in the background.
- Be available for me to visualise in Grafana.
- Grafana runs queries on a specified interval. Each time Grafana refreshes the data, it will rerun this query. In that way, I guess you could say it does run in the background.
- If you install the Grafana Flux plugin, yes, you’ll be able to use that query to visualize the data in Grafana. You may need to update some of the variables (
v.timeRangeStart,v.windowPeriod) to use Grafana variables, but I’m not sure.
