I have a full query where I am using the constant 1925.25 as a placeholder for what should be a variable (since it is the value of ETH/USD). My current query is this:
from(bucket: "Mining")
|> filter(fn: (r) => r["_measurement"] == "Miner")
|> filter(fn: (r) => r["_field"] == "balance")
|> filter(fn: (r) => r["tag1"] == "ethermine")
|> map(fn: (r) => ({r with _value: (float(v: r._value) / 1000000000000000000.0) * 1925.25 }))
|> aggregateWindow(every: 1h, fn: last)
|> derivative(unit: 1h, nonNegative: true, columns: ["_value"])
|> cumulativeSum(columns: ["_value"])
What I would like to do is use this data variable in place of the 1925.25, but I can’t figure out how to do that:
data = from(bucket: "Mining")
|> range(start: -10m)
|> filter(fn: (r) => r._measurement == "Miner")
|> filter(fn: (r) => r.tag1 == "flexpool")
|> filter(fn: (r) => r._field == "price")
|> last()
data
How would I use that in a single query so that I am getting the latest value for “price” for multiplication in the calculation above?
Both of the queries work fine and return what is expecetd in InfluxDB2 Data Explorer (FYI)
Thanks!
Tried so many things, but keep giving up.
