Hi I have the following variables in one query:
import "math"
latencyAverage = from(bucket:"telegraf")
|> range(start: v.timeRangeStart, stop: v.timeRangeStop )
|> filter(fn: (r) => r.host == "PRG-Vmontes-VElisa")
|> filter(fn: (r) => r._measurement == "nping_UDP")
|> filter(fn: (r) => r["nping-dest"] == "qt-brazil.tut.systems")
|> filter(fn: (r) => (r._field == "nping-avg"))
|> mean()
|> first()
|> rename(columns: { "_value": "latencyAverage_values" })
|> yield(name:"latencyAverage")
jitter = from(bucket:"telegraf")
|> filter(fn: (r) => (r._field == "nping-avg") or (r._field == "nping-pl_prct"), onEmpty: "keep")
|> map(fn: (r) => ({r with latency_values: float(v:r._value)}))
|> map(fn: (r) => ({r with packetLoss_values: float(v:r["nping-pl_prct"])}))
|> filter(fn: (r) => r.latency_values <= 49 or r.packetLoss_values <=1)
|> map(fn: (r) => ({r with latency_values: float(v: r["nping-avg"]),
percentage_values: float(v: r["nping-pl_prct"])}))
|> aggregateWindow(every:5m, fn: mean, createEmpty: true)
|> map(fn: (r) => ({r with finalResult: r["nping-avg"]/1.0}))
|> yield(name: "jitter")
latencyAverage returns this:
and jitter returns this:
what i cannot do is use the value from latencyAverage in the map inside the jitter equation:
I tried:
|> map(fn: (r) => ({r with finalResult: r["nping-avg"]/latencyAverage}))
I also tried:
|> map(fn: (r) => ({r with finalResult: r["nping-avg"]/latencyAverage.latencyAverage_values}))
When I do it, I get no result and sometimes timeouts.
what I am basically trying to ask, is how can i use that latencyAverage _value in this second variable jitter?
I cannot use join because it loads the cpu to 200% when I try to query the whole example.
I am sharing that working code here just to show that JOIN is something I tried but is not efficient
import "math"
tigoLatency = from(bucket:"telegraf")
//|> filter(fn: (r) => r.host== "PRG-Vmontes-VElisa" )
//|> filter(fn: (r) => r.host== "${ISP}" )
|> filter(fn: (r) => r._field == "nping-avg" )
|> filter(fn: (r) => r.latency_values < 120)
|> toFloat()
|> aggregateWindow(every: 30m, fn: count)
|> group()
//|> group(columns: ["host"])
|> rename(columns: { "_value": "latency_values" })
|> set(key: "status", value:"latency_column")
//|> yield (name:"tigoLatency")
tigoPacketLoss = from(bucket:"telegraf")
|> filter(fn: (r) => r._field == "nping-pl_prct" )
|> map(fn: (r) => ({r with packetLoss_values: r._value }))
|> filter(fn: (r) => r.packetLoss_values <= 1)
|> toFloat()
|> group()
|> rename(columns: { "_value": "packetLoss_values" })
|> set(key: "status", value:"packetLoss_column")
//|> yield (name:"tigoPacketLoss")
tigoSamples = from(bucket:"telegraf")
|> group(columns:["_time"])
|> group()
|> map(fn: (r) => ({r with samples: float(v: r._value) }))
|> set(key: "status", value:"sampleColumn")
//|> sort(columns: ["_time"], desc: false)
//|> limit(n: 10000 , offset: 1)
//|> yield (name:"tigoSamples")
//######################////////////////// JITTER /
entryA = from(bucket:"telegraf")
|> filter(fn: (r) => r._measurement == "nping_UDP" and r._field == "nping-avg")
|> aggregateWindow(every: 5m, fn: mean)
|> set(key: "status", value:"present")
//|> yield(name: "A")
entryB = from(bucket:"telegraf")
|> timeShift(duration: -5m, columns: ["_time"])
|> set(key: "status", value:"future")
//|> yield(name: "B")
final = join(
tables: {present: entryA, future: entryB},
on: ["_time", "host"],
method: "inner"
//|> group()
|> map(fn: (r) => ({r with _value: float(v: r._value_future - r._value_present) }))
|> filter(fn: (r) => (r._value > -100 ))
|> map(fn: (r) => ({r with _value: math.abs(x: r._value ) }))
|> filter(fn: (r) => (r._value < 5 ))
//|> group()
|> map(fn: (r) => ({r with jitter_values: float(v: r._value) }))
//|> yield(name: "final_jitter")
// ##################### ISP QUALITY #######################
ispLatPl = join(
tables: {latency_values: tigoLatency, packetLoss_values: tigoPacketLoss},
method: "inner"
|> map(fn: (r) => ({ r with latency_packetLoss_values: float(v: r.latency_values + r.packetLoss_values) }))
|> set(key: "status", value:"latency_packetLoss_column")
//|> yield(name: "latency_packetLoss_table")
ispLatPLJitter = join(
tables: {latency_packetLoss_values: ispLatPl, jitter_values: final},
method: "inner"
|> group()
|> map(fn: (r) => ({ r with latency_packetLoss_jitter: float(v: r.latency_packetLoss_values + r.jitter_values) }))
|> set(key: "status", value:"latency_packetLoss_jitter_column")
//|> drop(columns: ["_start_latency_values", "_stop_latency_values", "_start_packetLoss_values", "_stop_packetLoss_values",
// "host_latency_values", "host_packetLoss_values", "name_latency_values", "name_packetLoss_values",
// "type_latency_values", "type_packetLoss_values", "url_latency_values", "url_packetLoss_values",
// "status_latency_values", "status_packetLoss_values", "status_jitter_values", "status_latency_packetLoss_values",
//"_field_latency_values", "_field_packetLoss_values", "type", "url", "_measurement_latency_values",
// "_measurement_packetLoss_values", "_measurement", "name" ])
//|> yield(name: "latency_packetLoss_jitter_table")
ispQuality_1 = ispLatPLJitter
|> sort(columns:["host"])
|> toFloat()
|> set(key: "status", value:"isp_quality_1_column")
//|> yield(name: "ispQuality_1")
ispQuality = join(
tables: {latency_packetLoss_jitter: ispQuality_1, samples: tigoSamples},
method: "inner"
|> map(fn: (r) => ({r with result: ( if r.samples == 0.0 then 0.0 else r.latency_packetLoss_jitter / (r.samples*3.0)) }))
|> drop(columns: ["url", "type", "name", "host_samples", "_measurement",
"_field_samples", "_field_latency_packetLoss_jitter", "_start_latency_packetLoss_jitter", "_start_samples",
"_stop_latency_packetLoss_jitter", "_stop_samples", "status_latency_packetLoss_jitter", "status_samples",
"latency_values", "jitter_values", "latency_packetLoss_values", "packetLoss_values", "_value",
"_time_latency_packetLoss_jitter", "_field", "status", "_start_future", "_start_latency_values",
"_start_packetLoss_values", "_start_present", "_stop_future", "_stop_latency_values", "_stop_packetLoss_values",
"_stop_present", "_field_future", "_field_latency_values", "_field_packetLoss_values", "_field_present",
"_measurement_future", "_measurement_latency_values", "_measurement_packetLoss_values", "_measurement_present",
"name_future", "name_latency_values", "name_packetLoss_values", "name_present", "status_latency_values",
"status_packetLoss_values", "type_future", "type_latency_values", "type_packetLoss_values", "type_present",
"url_future", "url_latency_values", "url_packetLoss_values", "url_present",
"latency_packetLoss_jitter", "samples", "_value_samples", "_value_latency_packetLoss_jitter",
"nping-dest_latency_values", "nping-dest_packetLoss_values", "nping-dest_future", "nping-dest_present",
"nping-dest", "status"])
|> set(key: "status", value:"isp_quality_column")
|> rename(columns: {"result": " "})
|> yield(name: "ispQuality")
could anyone help me please?
