Migrating to flux math question
im currently trying to migrate to flux thanks to the query builder someone so familiar with flux can manage and i got everything working except 2 queries that use math to change the value displayed.
This is the query in question.
I just want to calculate the value *-1
 from(bucket: "telegraf")
     |> filter(fn: (r) => r["_field"] == "value")
     |> filter(fn: (r) => r["topic"] == "openWB/pv/1/W")
     |> yield(name: "mean")
My old query would be this
SELECT last("value")  *-1 FROM "mqtt_consumer" WHERE ("topic" = 'openWB/pv/W') AND $timeFilter GROUP BY time($__interval) fill(null)
i just could use math ( *-1) oder math ( *1000) but i have a hard time to figure out how to do this in flux.
From what i read i have to use map but i don’t know exactly how.
i have tried adding
|> map(fn: (r) => r._value * -1))
but that fails
hallo, be sure to combine same types
if i multiply my double 7.99 * -1 it returns
" runtime error @45:4-47:4: map: type conflict: int != float"
so changing -1 to -1.0 works ok
|> map(fn: (r) => ({negative : r._value_d1 * -1.0}))
pavel
Thanks worked changing *-1 to *1.0 i never would have thought of this
