fastxl
1
Using this query from this post
Difference Between 2 values in a query?
import "math"
First = from(bucket: "LB3000")
|> range(start: today())
|> filter(fn: (r) => r["deviceId"] == "Okuma-LB3000")
|> filter(fn: (r) => r["dataItemId"] == "Lppartcount")
|> toInt()
|> first()
Last = from(bucket: "LB3000")
|> toInt()
|> last()
union(tables: [First, Last])
|> difference()
I get a negative number as a result. I am expecting a positive number. When I try the suggested
|> map(fn: (r) => ({r with _value: math.abs(x: r._value)}))
I get a runtime error
runtime error @19:4-19:60: map: type conflict: float != int
Any suggestions? @grant1 ?
scott
2
@fastxl math.abs only accepts float values. You need to cast your value to a float and then back to an integer. Try the following:
|> map(fn: (r) => ({r with _value: int(v: math.abs(x: float(v: r._value)))}))
grant1
3
Thanks @scott and very clear as always.
I was about to suggest trying to reverse the two lines in the First and Last queries, like this:
OLD:
|> toInt()
|> first()
NEW:
|> first()
|> toInt()
and then see if the original map function would work…
fastxl
4
@scott Thanks for the help. I’d like to expand this to get a daily count for the last 7 days or any time frame. For each function by day?
Forget it. I found your work here Flux: First, Last and the differnce per day that answered this question.
