Hi how can use the value from my first variable as a divisor in my second variable?
import "math"
latencyAverage = from(bucket:"telegraf")
|> range(start: v.timeRangeStart, stop: v.timeRangeStop )
|> filter(fn: (r) => r.host == "PRG-host")
|> filter(fn: (r) => r._measurement == "nping_UDP")
|> filter(fn: (r) => r["nping-dest"] == "qt-brazil")
|> filter(fn: (r) => (r._field == "nping-avg"))
|> mean()
|> first()
|> rename(columns: { "_value": "latencyAverage_values" })
//|> yield(name:"latencyAverage")
jitter = from(bucket:"telegraf")
|> filter(fn: (r) => (r._field == "nping-avg") or (r._field == "nping-pl_prct"), onEmpty: "keep")
|> map(fn: (r) => ({r with latency_values: float(v:r._value)}))
|> map(fn: (r) => ({r with packetLoss_values: float(v:r["nping-pl_prct"])}))
|> filter(fn: (r) => r.latency_values <= 49 or r.packetLoss_values <=1)
|> map(fn: (r) => ({r with latency_values: float(v: r["nping-avg"]),
percentage_values: float(v: r["nping-pl_prct"])}))
|> aggregateWindow(every:5m, fn: mean, createEmpty: true)
|> toFloat()
|> map(fn: (r) => ({r with finalResult: r["nping-avg"]/latencyAverage}))
|> yield(name: "jitter")
This is my code and the last map() uses latencyAverage
