I’m using open telemetry to store metrics for my code. I want to filter out metrics for specific code paths taken rather than an aggregated view of all paths. I’m adding a hash based on the code path taken; Imagine this is the set of possible paths through my code
And for these paths I generate the following hashes:
A->C->E : 1
A->C->D : 2
B->C->D : 3
B->C->E : 4
Now I want to filter these paths, for example selecting “A” (in Grafana) should return paths 1 and 2 (A->C->E and A->C->D) but selecting “A”, “C” and “D” at the same time should only return path 2 (A->C->D).
I have managed to create tabular results that are grouped by nodes present in each path, but I can’t find any way to intersect / inner join a stream of multiple tables in order to get the correct paths.
Here is the influx query to re-produce this example:
import "array"
array.from(rows:[
{node: "A", path: 1},
{node: "C", path: 1},
{node: "E", path: 1},
{node: "A", path: 2},
{node: "C", path: 2},
{node: "D", path: 2},
{node: "B", path: 3},
{node: "C", path: 3},
{node: "D", path: 3},
{node: "B", path: 4},
{node: "C", path: 4},
{node: "E", path: 4}
|> filter(fn: (r) => r.node == "A" or r.node == "C" or r.node == "D")
|> group(columns: ["path"])
The problem is that because I’m including “C” which is common in all paths, I need to intersect / inner join paths in all of the groups / tables / stream. I know in this specific simplified example leaving out “C” solves the issue but this is just a simplified example, not the actual use case.
Can you please help me get the correct output (path 2) from the reproducible query above?
