Flux help required
currently I’m struggling with joining two tables together. Maybe someone has an idea, as I’m driving crazy understanding the possibilities of flux.
Suppose the following two tables:
left = from(bucket: "pon")
   |> range(start: v.timeRangeStart, stop:v.timeRangeStop)
   |> filter(fn: (r) => r._measurement == "zum")
   |> filter(fn: (r) => r._field == "value")
   |> aggregateWindow(every: 1m, fn: mean)
   |> timeShift(duration: -1m)
// don't know if this is needed, but it didn't help anyway
   |> truncateTimeColumn(unit: 1m)
with the following example results
See comment below
and the right table:
right = from(bucket: "pon")
   |> filter(fn: (r) => r._measurement == "cur")
with the following example data
But when I join the tables together on tag id and also keep all other column from both tables.
This is my join statement
join.full(
left: left,
right: right,
on: (l, r) => l.id== r.id,
as: (l, r) => ( {l with id: l.id} )
This is the first table
@sparkitny Welcome to the influxdata community!
Looking at your tables and code, there are a couple of issues to address:
Issue 1: Column Name Conflicts
Your tables have columns with the same names (_time, _measurement, _field, _value). You need to rename these columns to avoid conflicts.
Issue 2: Join Syntax
The as parameter in your join needs to include all columns you want to keep from both tables.
Here are a few ways to fix your join query:
Method 1: Rename columns before joining to avoid conflicts
left_renamed = from(bucket: "pon")
    |> rename(columns: {_value: "zum_value", _field: "zum_field", _measurement: "zum_measurement"})
right_renamed = from(bucket: "pon")
    |> rename(columns: {_value: "cur_value", _field: "cur_field", _measurement: "cur_measurement"})
// Join with proper handling of all columns
joined = join.full(
    left: left_renamed,
    right: right_renamed,
    on: (l, r) => l.id == r.id and l._time == r._time,
    as: (l, r) => ({
        _time: l._time,
        zum_value: l.zum_value,
        cur_value: r.cur_value,
        cid: r.cid,
        com: r.com,
        d1: r.d1,
        ppid: r.ppid
Method 2: Using join.inner with better column handling
alternative_join = join.inner(
    left: left_renamed,
    as: (l, r) => ({l with // Start with all left columns
        cid: r.cid,
        com: r.com,
        d1: r.d1,
        ppid: r.ppid
Method 3: If you need to keep all rows from both tables
full_join_all_columns = join.full(
    left: left_renamed,
    on: (l, r) => l.id == r.id,
    as: (l, r) => {
        // Handle cases where one side might be empty
        id = if exists l.id then l.id else r.id
        time = if exists l._time then l._time else r._time
        return {
            _time: time,
            zum_field: l.zum_field,
            zum_measurement: l.zum_measurement,
            cur_field: r.cur_field,
            cur_measurement: r.cur_measurement,
            cid: r.cid,
            com: r.com,
            d1: r.d1,
            ppid: r.ppid
If you want to filter the result to only show specific columns:
final_result = joined
    |> keep(columns: ["_time", "id", "zum_value", "cur_value", "cid", "com", "d1", "ppid"])
Key points to remember:
  1. Always rename conflicting columns before joining
  2. Include all columns you want to keep in the as parameter
  3. Use both id and _time in your join condition if you want to match on both
  4. Consider using join.inner() if you don’t need rows where there’s no match in one table
Let me know if you need any clarification on these solutions!
