I want to perform a query that returns the values of a measurement while another measurement have a specific value.
For instance:
- While the value of the following query is 7
QUERY 1 = filter (measurement = variables) (filter 1 = 1) (filter 2 = “stm”)
- Return the values of the following query
QUERY 2 = filter (measurement = variables) (filter 1 = 1) (filter 2 = “tiempo/emergencia”)
-Therefore, I can perform a calculation of the new table.
I have researched a bit and I have found that I can use join to perfrom a similar query but it will only return the rows where the _time is identical, instead I want
the query to return all the values of QUERY 2 while the result the resul of QUERY 1 has a value 7 (“stm” = 7)
dataStream1 = from(bucket: “iot”)
|> filter(fn: (r) => r[“_measurement”] == “variables”)
|> filter(fn: (r) => r[“entity”] == “1”)
|> filter(fn: (r) => r[“var_id”] == “stm”)
|> filter(fn: (r) => r._value == 7)
dataStream2 = from(bucket: “iot”)
|> filter(fn: (r) => r[“var_id”] == “tiempo/emergencia”)
join(
tables: {d1:dataStream1, d2:dataStream2},
on: [“_time”]
Is there any way of returning the values of a table (dataStream2) While the value of another table (dataSteram1) have a specific
A more visual explanation might help understand my goal. DataStream1 change the stage less often than DataStream2 as you can see in the images attached. My goal is to generate a table with all the values of dataStream2 while dataStream1 is 7. As you can see in the joned table, i only get the row that matches exactly the _time column but I want to get all values from 2021-08-06T06:09:33.14Z to 2021-08-06T06:11:33.168Z. Link bellow.
