Interrupt plugin not working
i tried using the interrupt plugin [[inputs.interrupt]] and set the cpu_as_tag parameter to true in telegraf.
but the plugin didn’t create any measurements as expected.
not only it fails to create a new measurement and populate data into that but after restarting telegraf other measurements also stop getting populated. once i remove this plugin from the configuration file nad restart telegraf again everything goes back to normal.
can anyone please help with this situation?
Hi @neo1702
there is an ‘s’ missing … it should be :
[[inputs.interrupts]]
best regards
yeah… sorry that’s a typo… that doesn’t exist in the configuration file.
#Gathers metrics about IRQs
cpu_as_tag = true
##When set to true, cpu metrics are tagged with the cpu. Otherwise cpu is
##stored as a field
that’s how it is written in the configuration file.
Hi @neo1702 ,
can you test as follows ?
create a file configtest with the following lines …
[[outputs.file]]
files = ["/tmp/testing.out"]
cpu_as_tag = true
and then run in the same directory where the configtest file is : telegraf --config configtest --test
getting this error:
Error running agent: Error parsing fileName, line 76: field corresponding to cpu_as_tag is not defined in *interrupts.Interrupts
hi @neo1702 ,
i should have asked first : what is your telegraf version ?
telegraf -version
ps : your configtest file has at least 76 lines ?
Telegraf 1.9.2
actually i used the original config file only that’s why 76 lines.
everything else is commented.
I have tested it with your version and I get the same error ,
with version 1.11 it works …
:tired_face:
thank you for the effort.
any suggestions??
if you uprade telegraf to the latest version it will work . ( I have tested it with 1.11.2 :slight_smile: )
thank you for the help
