Hi @alvianno,
Do you have some more information ?
What is the state of your database ?What is your question ?
What is the link with logparser?
Best regards
my database no problem, telegraf read file csv with plugin logparser, but if many insert to database i look log error in log telegraf is client timeout
Hi @alvianno , can you share the agent section of your Telegraf configuration ?
Telegraf Configuration
Telegraf is entirely plugin driven. All metrics are gathered from the
declared inputs, and sent to the declared outputs.
Plugins must be declared in here to be active.
To deactivate a plugin, comment out the name and any variables.
Use ‘telegraf -config telegraf.conf -test’ to see what metrics a config
file would generate.
Environment variables can be used anywhere in this config file, simply prepend
them with $. For strings the variable must be within quotes (ie, “$STR_VAR”),
for numbers and booleans they should be plain (ie, $INT_VAR, $BOOL_VAR)
Global tags can be specified here in key=“value” format.
[global_tags]
dc = “us-east-1” # will tag all metrics with dc=us-east-1
rack = “1a”
Environment variables can be used as tags, and throughout the config file
user = “$USER”
Configuration for telegraf agent
[agent]
Default data collection interval for all inputs
interval = “10s”
Rounds collection interval to ‘interval’
ie, if interval=“10s” then always collect on :00, :10, :20, etc.
round_interval = true
Telegraf will send metrics to outputs in batches of at most
metric_batch_size metrics.
This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 10000
For failed writes, telegraf will cache metric_buffer_limit metrics for each
output, and will flush this buffer on a successful write. Oldest metrics
are dropped first when this buffer fills.
This buffer only fills when writes fail to output plugin(s).
metric_buffer_limit = 100000
Collection jitter is used to jitter the collection by a random amount.
Each plugin will sleep for a random time within jitter before collecting.
This can be used to avoid many plugins querying things like sysfs at the
same time, which can have a measurable effect on the system.
collection_jitter = “0s”
Default flushing interval for all outputs. Maximum flush_interval will be
flush_interval + flush_jitter
flush_interval = “10s”
Jitter the flush interval by a random amount. This is primarily to avoid
large write spikes for users running a large number of telegraf instances.
ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = “0s”
By default or when set to “0s”, precision will be set to the same
timestamp order as the collection interval, with the maximum being 1s.
ie, when interval = “10s”, precision will be “1s”
when interval = “250ms”, precision will be “1ms”
Precision will NOT be used for service inputs. It is up to each individual
service input to set the timestamp at the appropriate precision.
Valid time units are “ns”, “us” (or “µs”), “ms”, “s”.
precision = “ns”
Logging configuration:
Run telegraf with debug log messages.
debug = false
Run telegraf in quiet mode (error log messages only).
quiet = false
Specify the log file name. The empty string means to log to stderr.
logfile = “”
Override default hostname, if empty use os.Hostname()
hostname = “”
If set to true, do no set the “host” tag in the telegraf agent.
omit_hostname = false
OUTPUT PLUGINS
Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
The full HTTP or UDP URL for your InfluxDB instance.
Multiple URLs can be specified for a single cluster, only ONE of the
urls will be written to each interval.
urls = [“unix:///var/run/influxdb.sock”]
urls = [“udp://127.0.0.1:8089”]
urls = [“http://172.16.11.124:8086”]
The target database for metrics; will be created as needed.
For UDP url endpoint database needs to be configured on server side.
database = “LOG_KPEI”
The value of this tag will be used to determine the database. If this
tag is not set the ‘database’ option is used as the default.
database_tag = “”
If true, no CREATE DATABASE queries will be sent. Set to true when using
Telegraf with a user without permissions to create databases or when the
database already exists.
skip_database_creation = false
Name of existing retention policy to write to. Empty string writes to
the default retention policy. Only takes effect when using HTTP.
retention_policy = “autogen”
Write consistency (clusters only), can be: “any”, “one”, “quorum”, “all”.
write_consistency = “any”
Timeout for HTTP messages.
timeout = “60s”
HTTP Basic Auth
username = “telegraf”
password = “metricsmetricsmetricsmetrics”
HTTP User-Agent
user_agent = “telegraf”
UDP payload size is the maximum packet size to send.
udp_payload = “512B”
Optional TLS Config for use on HTTP connections.
tls_ca = “/etc/telegraf/ca.pem”
tls_cert = “/etc/telegraf/cert.pem”
tls_key = “/etc/telegraf/key.pem”
Use TLS but skip chain & host verification
insecure_skip_verify = false
HTTP Proxy override, if unset values the standard proxy environment
variables are consulted to determine which proxy, if any, should be used.
http_proxy = “http://corporate.proxy:3128”
Additional HTTP headers
http_headers = {“X-Special-Header” = “Special-Value”}
HTTP Content-Encoding for write request body, can be set to “gzip” to
compress body or “identity” to apply no encoding.
content_encoding = “identity”
When true, Telegraf will output unsigned integers as unsigned values,
i.e.: “42u”. You will need a version of InfluxDB supporting unsigned
integer values. Enabling this option will result in field type errors if
existing data has been written.
influx_uint_support = false
###################### INPUT ########################################
[[inputs.logparser]]
Log files to parse.
These accept standard unix glob matching rules, but with the addition of
** as a “super asterisk”. ie:
/var/log/**.log → recursively find all .log files in /var/log
/var/log//.log → find all .log files with a parent dir in /var/log
/var/log/apache.log → only tail the apache log file
files = [“/media/logs/crappie21/mongodb/mongod.log”]
from_beginning = true
Method used to watch for file updates. Can be either “inotify” or “poll”.
watch_method = “inotify”
Parse logstash-style “grok” patterns:
Telegraf built-in parsing patterns: https://goo.gl/dkay10
[inputs.logparser.grok]
patterns = [‘’‘%{TIMESTAMP_ISO8601:timestamp:ts-“2006-01-02T15:04:05.999+0700”}\s%{WORD:Log_Level:tag}\s%{NOTSPACE:Log_Type:tag}\s+[%{ERROR_CODE:Error_Code:tag}(%{NUMBER:Error_Code_Number:drop}?)]\s%{GREEDYDATA:Message:string}?’‘’]
unique_timestamp = “disabled”
measurement = "MongoDB"
custom_pattern_files = []
custom_patterns = '''ERROR_CODE [a-zA-Z-]*
timezone = "local"
Hi ,
does it always take around 3 s to write 100.000 measurements ?
you will have to find out if something is slowing down your system …
The log is from during the night ?
Do you have the same problem during the day ?
Does the problem occur always around the same time ?
for the first error : output "influxdb" did not complete within its flush interval
you could increase the flush_interval … .
for the second error : Timeout exceeded while awaiting headers
can you check what happens on the database around that time ? Heavy load ? CQ’s ?
