Hi all,
I have been trying to parse 3 values on separate URLs via the XML parser. However nothing shows up in the X2 bucket in influxdb. In my config file I have already another input source (X1) that is saved in the X1 bucket in the same database. I have tried to separate those 2 inputs and outputs via tagexclude . Does anybody see where the problem lies?
Many thanks!
Please see below my entire config file:
[agent]
interval = "5s"
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Log at debug level.
# debug = false
## Log only error level messages.
# quiet = false
## Log target controls the destination for logs and can be one of "file",
## "stderr" or, on Windows, "eventlog". When set to "file", the output file
## is determined by the "logfile" setting.
# logtarget = "file"
## Name of the file to be logged to when using the "file" logtarget. If set to
## the empty string then logs are written to stderr.
# logfile = ""
## The logfile will be rotated after the time interval specified. When set
## to 0 no time based rotation is performed. Logs are rotated only when
## written to, if there is no log activity rotation may be delayed.
# logfile_rotation_interval = "0d"
## The logfile will be rotated when it becomes larger than the specified
## size. When set to 0 no size based rotation is performed.
# logfile_rotation_max_size = "0MB"
## Maximum number of rotated archives to keep, any older logs are deleted.
## If set to -1, no archives are removed.
# logfile_rotation_max_archives = 5
## Pick a timezone to use when logging or type 'local' for local time.
## Example: America/Chicago
# log_with_timezone = ""
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
[[outputs.influxdb_v2]]
urls = ["http://192.168.X.X:XXXX"]
## Token for authentication.
token = "XXX"
organization = "XXX"
bucket = "X1"
tagexclude =[“tag1”]
[outputs.influxdb_v2.tagpass]
tag1 = [“X1”]
[[inputs.http]]
urls = ["http://192.168.X.XX/getvar.csv"]
data_format = "csv"
csv_header_row_count = 1
csv_measurement_column = "name"
csv_tag_columns = ["id"]
csv_column_types = ["string","float","string","string","string","string"]
[inputs.socket_listener.tags]
tag1 = “X1”
[[processors.converter]]
[processors.converter.fields]
float = ["val"]
#___________ X2 _________________
token = "YYY"
bucket = "X2"
tagexclude =[“tag2”]
tag2 = [“X2”]
[[inputs.http]]
urls = ["http://192.168.X.X/cgi-bin/webgui.fcgi?xmlitem=34.4001",
"http://192.168.X.X/cgi-bin/webgui.fcgi?xmlitem=34.4022",
"http://192.168.X.X/cgi-bin/webgui.fcgi?xmlitem=34.4033"]
data_format = "xml"
tagexclude = ["url", "host"]
## Multiple parsing sections are allowed
[[inputs.tail.xml]]
## Optional: XPath-query to select a subset of nodes from the XML document.
#metric_selection = "/pm5"
[inputs.http.xml.tags]
id = "id/@name"
## Non-integer field definitions using XPath queries.
## The field type is defined using XPath expressions such as number(), boolean() or string(). If no conversion is performed the field will be of type string.
[inputs.http.xml.fields]
type = "number(/item/@type)"
label = "string(/item/@label)"
unit = "string(/item/@unit)"
value = "number(/item/@value)"
tag2 = “X2”
The XML code looks like this:
